Slight tangent, but The eizo foris 2421 was a total debacle. Somehow eizo seem to have a reputation for quality but from my own experience and many others of that model, it's not like that at all. I would hope that particular model was an odd blip, but it's tarnished their image for me.
I agree, I had this monitor for about a year and I found the colour accuracy was lacking - it was difficult to calibrate to my satisfaction.
I also found the gamma uniformity, viewing angles and input lag to be quite poor overall.
The 120hz and Turbo240 mode was very good in terms of motion clarity but it did have some crosstalk in the corners that detracted from the benefit it afforded.
Owch. Well that blow hurt like a kick to the groin.
If that's true Baddass, that's really bad news for all of us. I wonder if there is anything else coming soon that might take it's place?
I hate to burst everyone's bubble but Eizo have told me that as it stands at the moment they are not planning to Launch this model in the UK. I've asked them to reconsider and requested a review sample which is expected over the coming months. It will be available to order via Europe I believe unless Eizo change their stance on UK supply
Badass, pcm2, simon (tftcentral), or anyone who can get a sample of this thing:
Do you guys (or does anyone) know the full range of blur reduction on this thing?
namely:
does it do single strobing or double strobing? the previous motion 240 monitors strobed TWICE per refresh, while the benq monitors strobed ONCE per refresh.
Can it strobe at 100hz or down to 60hz? And if so, can it single strobe down here? The previous FS2421 Foris would only strobe in the 105hz-120hz range (tested by Chief Blur Buster of the blurbusters' site).
Sorry for being so naggy but the XL2730Z completely tilted me. I wanted to upgrade from my XL2720Z but the broken strobing is useless for me (I play games that require 91hz single strobe, 100hz single strobe, 60hz (street fighter, dark souls, etc). And the XL2730Z won't strobe under 120hz and Benq claimed they couldn't fix this with a Fw update (all it is is a simple SYNC bug. I can make even the XL2720Z, which can Single strobe at 60h-144hz) mess up by using the exact vertical total designed for a different refresh rate. But the XL2730Z does not respond to vertical totals anymore, while all of the other Z monitors did).
If only they could develop a 24" 144hz IPS 1080p panel.
thats what Eizo have told me. I have spoken directly to the Foris product manager and at the moment there aren't plans to release directly in UK. However, it will be available from some big stores online who ship from Europe so it will still be available. I should still get hold of a review sample, but apparently that's not expected until Dec time so i doubt we will see retail stock until the new year
Nowhere did I read that you can combine backlight strobing and freesync.
Where did they say you can do this? I didn't see anything that said they COMBINED it together to be activated at once....
This could be very possible but this would not work well if using single strobing. Chief blur buster wrote an article about combing strobing and variable refresh rates, but if you drop below 72hz, you start getting flicker that is noticeable by anyone (the first "flicker free VGA monitors were 72hz, btw) and once you get down to 50hz, the flickering can make people sick. (you can make the benq blur reduction 1.0 monitors single strobe at 50hz by using a 1360 vertical total via custom resolution; otherwise the backlight will get overvolted, strobing won't activate at 50hz and the monitor may overvoltage power cycle itself).
If this is double strobing, it could work at 50hz (the Benq monitors can officially double strobe at 50hz, even the V1 firmware for the original Z series before strobe adjustments were available) but double strobing lower than 85hz is ugly. very ugly.
