The GTX 980 Ti owners thread.
thanks all that helped bit of coil whine....
but boosted up to 1415 out of box so will play tommorow.
bottom card is 9 degress hotter but might just need to setup my bottom rad fans to push more.
http://www.techpowerup.com/216452/msi-announces-geforce-gtx-980-ti-gaming-golden-edition.html
Oo higher quality pictures.
Still looks far too orange to be considered a "Golden" card in my opinion. It's very Halloween themed though.
Anyhow here is a picture of the unfinished ( i know it looks messy but it was 1:30 ! in morning and had to be up at 5 ;) )
Gota sort the cabling out it does look unique with it in serial though so here is a plus.
Running the witcher 3 the top card reached 42c and the bottom 36c. They only really getting to 55% usage though at 1440p 60hz.
Very happy my first proper custom loop its not how i would do it again but it works and when tidied up wont look that bad :)
Looks awesome - Phanteks Primo I assume? Also, can you change the LEDs at all?
You need to change that SLI bridge though! :p
Get the two cards working 100% to get a proper temperature test, fire up Heaven and run for about 15 mins with Vsync off.
Looks like it's doing fine, and well done on your first loop!
You assume correct :) what started of me wanting a EVGA hybrid for my old setup quickly become a full replacement with loop.
Tell me about it just cant find one that suits currently
