Again interesting, as I've left all my clocks at stock.
High hard pagefaults doesn't mean much though, just that it had to fetch data from a HDD instead of memory, which will happen all the time.
How's your DPC execution time now? 600?
No, it remained exactly the same at about <1500.
I don't know why that is, i'm assuming its normal, unless someone with a Maxwell card gets significantly less?
Windows 8.1?
Pretty interesting there. I do know latency is higher on nvidia cards because of true multithreading, the tradeoff between deferring less important processing to idle cores over a bit of extra latency.
I have seen some people who have <1ms. However, I can't confirm if they were playing games or stress testing. If it was on idle just desktop browsing it wouldn't be much of a surprise. Is yours only 1500ish when stressing?
Windows 10, yeah, its practically nothing at idle, it only goes up that high if the GPU is loaded.
Any actual symptoms like my audio skipping, or is this just annoying to you?
