When I first got my speed I had an old backpack that sat on the seat cowl which eventually caused some small scratches, the type of scratch that you get when you put something in your pocket with your keys for too long.
Is that something that t-cut would sort, or is there something else I should be using?
They're not too bad and most of them rubbed out, but want to get rid of all of them.
If it would do the trick, do I get the actual t-cut scratch remover paste stuff, or should I just go for the original liquid stuff in a red bottle.
Thanks.
Thanks.
Always treat my girls to a MER shampoo and polish
