Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
42" PC monitor?!
It's not a fixie is it? I'm assuming since it's got brakes it's a freewheel? You can't ride a fixie unless you've got a beard, jorts and sport a man bun.
bimbleuk what's the quality like compared to Asus?
500 pheasant and 10 fox cartridges
If you're not fussy and are prepared to import direct from the Korean seller on Ebay then there are several 40-42" 4K UHD monitors available on Ebay. They do chroma 4:4:4 so work perfectly as PC monitors. Mines an AMH A399U which is being super seeded by the A402U. Inky black VA type panel and ~5ms response so not bad for casual gaming.
For scale that's my old Asus 27" VG278 144Hz monitor sat above it.
I'm typing now in one 1080p window and have the Grand Prix open in another in the top right corner.
http://s154.photobucket.com/user/bi...elated/A399U_Dying_Light_zpsbmtmpwbu.jpg[/URL
What vertical monitor stand do you use to hold those two up?
Got myself a Regatta cacky brown coat to keep warm and dry and pair of leather slippers to keep my feet warm
It looks slightly better in flesh but it was only 29 quid
New Boots and Gloves.![]()
Are those motorcycle boots?
Man they look sweet, can't wait to get into motorbiking!
When will that be?![]()
Cant see the slippers doing a good job of keeping you dry. A pair of walking boots might have been better.
