The GTX 980 Ti owners thread.
I can't understand why people still blame the Gigabyte coil whine on PSU's. Did your previous GPU have coil whine? Did the GPU before that?
Why is a PSU suddenly the problem when a Gigabyte G1 gets powered from it?
It's the cards that cause the whine, not the PSU!
In some instances it can be the psu, there's example on here and other forums people swapping out their psu and it minimising or eliminating coil whine.
That's beautiful Spike, love the CPU to GPU pipe.
I had a G1 Gaming that whined, whilst the GTX 980 it replaced didn't whine, replaced G1 Gaming, whined, replaced it again, still whined, replaced PSU (Corsair CX750 to SuperFlower Leadex Gold 850W), still whined but admittedly not nearly as bad, sold the G1 Gaming & replaced it with a Strix, Strix whines a whole lot less - But the guy who bought the G1 Gaming said it had no whine whatsoever..
Capping FPS using RivaTuner has basically made my card inaudible though, but that shouldn't be something you have to do really.
Thanks Joe! It was a beast of a build I can tell you!
I'm currently running a pair of the EVGA reference design 980ti SC in SLi. I'm getting temperatures of up to and around 80-85° between the cards, when not particularly under load. Nothing too strenuous or demanding but higher than expected when gaming. Am I to believe this is just how these newer cards run? They run at high temps with boost, and then throttle when hitting 85°?
Or should I be concerned?
I am running at 1440 resolution, and at 144MHz on the ASUS Swift panel as in my sig. I've got a well cooled, roomy case with good airflow, pulling in air from the front and bottom and venting from the rear and top.
Any reassurance would be appreciated, as I'd hate to think I'm shortening the life of these amazing cards.
Thanks,
Bozzler.
With stock fan curve those temps are fine (even the single card is setup to get to 85 degrees).
If you're not happy with it you can pick up the EVGA AIO cooler for 90£, but there's nothing wrong with your cards.
If I recall correctly, your card will never be "truly" idle if you have your refresh rate set to 144Hz for the Windows desktop, however setting it to 120Hz seems to fix this. A user had the same problem with his core clocks never dropping at idle (which I assume is why your cards are running hot) here - http://forums.overclockers.co.uk/showthread.php?t=18631230 - There were a couple of posts explaining how to fix it :)
This is my nVidia history after a long period with AMD cards. I've still got the GTX 670 in a Q6600 based system.
For scale that's an 27" Asus VG278 144Hz TN panel sitting above my Korean UHD panel :)
I'll have to look back through the 980 Ti thread and see if I've missed any tricks!
Which monitor arm/stand are you using? My end goal is to have a similar setup with my 1440/144 swift on the bottom with a 23" 4k unit above for secondary/ps4 duties.
I think I answered I n more detail in another thread but at the time the Asus was sat on the printer shelf hidden behind the 40" panel. I've since fitted an Ergotron arm on the wall holding a 22" HP as I've sold the Asus. Main display is sat on a TV style stand, two legs, flat glass base.
Sorry for the awful pics :o
I'll do better when it eventually goes underwater.
Not done anything at all with it yet. Just spent the last few hours wrestling trifire out (acrylic tubing, custom panels and the triple bridge made it a right ballache) and rejigging the loop.
Cheers mate :)
Yeah, but that's probably going to wait until I've decided on a new case/mATX mobo.
I've got my beady eyes on one of these. Just can't decide on which one...
I'm sure this'll do just fine, but I'm gonna miss the trifire setup :(
Sure, I didn't use all three that often, but it was nice to have it if needed and as you know, you can't beat the pimpery of multi card WC :D
Which 980 ti do you have please.:)
Cheers mate :)
Black one all day long - really do like the Heatkiller stuff :cool:
Aye, nothing beats a decent multi gpu set up for looks
Welcome and on TROH.:)
The Roll of Honour.
Make EVGA SC ACX, Uncle Petey, Link, Date 13/10/2015
Make Gigabyte G1, razorpakk, Link, Date 09/10/2015
Make EVGA SC Ref, bimbleuk, Link, Date 09/10/2015
Make EVGA SC Ref, tyler_jrb, Link, Date 09/10/2015
Make MSI Gaming, seanyc5, Link, Date 08/10/2015
Make Asus Strix, drex69, Link, Date 07/10/2015
Make Asus Strix, Joe!, Link, Date 05/10/2015
Make KFA2 HOF, Intra-Agnostic, Link, Date 02/10/2015
Make KFA2 HOF, ratters, Link, Date 01/10/2015
Make Palit Super Jetstream, Watlinguk, Link, Date 30/09/2015
Make EVGA Classified, Dicehunter, Link, Date 30/09/2015
Make EVGA SC ACX, ashjones86, Link, Date 30/09/2015
Make Inno3D X3, AWPC, Link, Date 28/09/2015
Make Gigabyte G1, [Death], Link, Date 27/09/2015
Make Inno3D Hybrid, Porl, Link, Date 25/09/2015
Make MSI Gaming, evilmatt, Link, Date 24/09/2015
Make Inno3D Hybrid, Hiijinx, Link, Date 09/09/2015
Make OcUK Tech Labs, offmyed, Link, Date 08/09/2015
Make Inno3D Hybrid, Boomstick777, Link, Date 07/09/2015
Make Gigabyte G1, uscool, Link, Date 06/09/2015
Make MSI Gaming, Awahwah, Link, Date 06/09/2015
Make EVGA SC Ref, Bozzler, Link, Date 05/09/2015
Make Palit Super Jetstream, lowrider007, Link, Date 04/09/2015
Make MSI Gaming, JABenedicic, Link, Date 03/09/2015
Make Zotac AMP Extreme, PakJai, Link, Date 03/09/2015
Make EVGA Classified, supermoose1111, Link, Date 03/09/2015
Make EVGA SC ACX, IceWolf, Link, Date 03/09/2015
Make MSI Gaming, anticonscience, Link, Date 02/09/2015
Make Palit Super Jetstream, artus, Link, Date 01/09/2015
Make Zotac AMP Extreme, Muzza1875, Link, Date 29/08/2015
Make Reference, Mysterae_, Link, Date 29/08/2015
Make Asus Strix, andybird123, Link, Date 29/08/2015
Make MSI Gaming, andybird123, Link, Date 29/08/2015
Make Palit Super Jetstream, ryryryan, Link, Date 28/08/2015
Make MSI Gaming, traveyb, Link, Date 28/08/2015
Make EVGA Classified, Alisdair, Link, Date 27/08/2015
Make KFA2 HOF, Gudu55, Link, Date 27/08/2015
Make MSI Gaming, davewhite04, Link, Date 27/08/2015
Make Zotac AMP Extreme, Ravenger, Link, Date 21/08/2015
Make Palit Super Jetstream, Aretak, Link, Date 20/08/2015
Make KFA2 HOF, McNappa, Link, Date 19/08/2015
Make EVGA ACX, Saftlad, Link, Date 19/08/2015
Make KFA2 HOF, SeanDrake, Link, Date 18/08/2015
Make Zotac AMP Extreme, ntemples1, Link, Date 17/08/2015
Make Palit Super Jetstream, DustyMiller, Link, Date 16/08/2015
Make MSI Gaming, duey33, Link, Date 15/08/2015
Make MSI Gaming, felton1592, Link, Date 15/08/2015
Make KFA2 HOF, kablooey, Link, Date 14/08/2015
Make Reference, barmyllama, Link, Date 13/08/2015
Make EVGA Classified, zia, Link, Date 12/08/2015
Make MSI Gaming, Ali_Carns, Link, Date 12/08/2015
Make Reference, jrodga2k5, Link, Date 11/08/2015
Make Reference, Boomstick777, Link, Date 09/08/2015
Make Palit Super Jetstream, iB CoMpL3XiTy, Link, Date 07/08/2015
Make Asus Strix, Gerard, Link, Date 07/08/2015
Make MSI Gaming, altus, Link, Date 05/08/2015
Make MSI Gaming, PrinceNelson, Link, Date 05/08/2015
Make Inno3D X3, dan76, Link, Date 04/08/2015
Make EVGA Classified, Tommy_Here, Link, Date 04/08/2015
Make MSI Gaming, Arcane, Link, Date 02/08/2015
Make EVGA Classified, VEGACORTEZ, Link, Date 02/08/2015
Make MSI Gaming, evsknight, Link, Date 01/08/2015
Make Zotac AMP Extreme, Navin, Link, Date 01/08/2015
Make MSI Gaming, Arkie, Link, Date 31/07/2015
Make MSI Gaming, Superpatsy, Link, Date 31/07/2015
Make Inno3D Hybrid, Minarva, Link, Date 30/07/2015
Make Inno3D X4, rolypolyman, Link, Date 29/07/2015
Make Inno3D Hybrid, ghutchison14078, Link, Date 29/07/2015
Make Zotac AMP Extreme, marcus2704, Link, Date 29/07/2015
Make Inno3D Hybrid, GoblinKingUK, Link, Date 29/07/2015
Make EVGA Kingpin, Brutus, Link, Date 28/07/2015
Make KFA2 HOF, Adzassin, Link, Date 27/07/2015
Make MSI Gaming, FMTopfan, Link, Date 24/07/2015
Make MSI Gaming, majnu, Link, Date 23/07/2015
Make Zotac AMP Extreme, Frenzy, Link, Date 23/07/2015
Make Zotac AMP Edition, CEUOTC, Link, Date 22/07/2015
Make MSI Gaming, OvEr_KiLL, Link, Date 20/07/2015
Make MSI Gaming, anewhope, Link, Date 19/07/2015
Make MSI Gaming, KLM, Link, Date 17/07/2015
Make MSI Gaming, Devious, Link, Date 17/07/2015
Make EVGA SC ACX, Temp.sgk, Link, Date 16/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 16/07/2015
Make Zotac AMP Extreme, Yulaw, Link, Date 16/07/2015
Make Asus Strix, PurE GaminG, Link, Date 15/07/2015
Make Gigabyte G1, String, Link, Date 14/07/2015
Make Palit Super Jetstream, Spit, Link, Date 14/07/2015
Make Gigabyte G1, McShave, Link, Date 13/07/2015
Make MSI Gaming, Boomstick777, Link, Date 12/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 11/07/2015
Make EVGA Classified, kael13, Link, Date 11/07/2015
Make Zotac AMP Extreme, currob, Link, Date 10/07/2015
Make Zotac AMP Extreme, Metalface Mark, Link, Date 10/07/2015
Make MSI Gaming, Mallers, Link, Date 09/07/2015
Make MSI V1, samcat, Link, Date 09/07/2015
Make MSI Gaming, Jeps, Link, Date 08/07/2015
Make EVGA Hybrid, F1aw1ess, Link, Date 07/07/2015
Make Zotac AMP Edition, sunn, Link, Date 06/07/2015
Make EVGA Hybrid, DVR, Link, Date 06/07/2015
Make MSI Gaming, Firefox35, Link, Date 05/07/2015
Make MSI Gaming, 40Four, Link, Date 03/07/2015
Make MSI Gaming, Ghosteh, Link, Date 03/07/2015
Make MSI Gaming, arknor, Link, Date 02/07/2015
Make Reference, amigafan2003, Link, Date 02/07/2015
Make Reference, savagesam117, Link, Date 01/07/2015
Make Gigabyte G1, Combat Fighter, Link, Date 01/07/2015
Make OcUK Tech Labs, NoobCannon, Link, Date 01/07/2015
Make EVGA Hybrid, Joe_Easy, Link, Date 01/07/2015
Make Inno3D Herculez, IceWind, Link, Date 01/07/2015
Make Gigabyte G1, Ashley Jordan, Link, Date 01/07/2015
Make Reference, colinmcr, Link, Date 30/06/2015
Make Gigabyte G1, Doco, Link, Date 30/06/2015
Make Zotac AMP Edition, digitalx, Link, Date 30/06/2015
Make Gigabyte G1, Robzere31, Link, Date 30/06/2015
Make MSI Gaming, Five.Stars, Link, Date 29/06/2015
Make Gigabyte G1, Fire_fly, Link, Date 29/06/2015
Make MSI Gaming, Radeon123, Link, Date 29/06/2015
Make MSI Gaming, setter, Link, Date 29/06/2015
Make Gigabyte G1, plazyma, Link, Date 29/06/2015
Make Gigabyte G1, rossiboy001, Link, Date 29/06/2015
Make Reference, toodoo9011, Link, Date 29/06/2015
Make Gigabyte G1, rootz, Link, Date 29/06/2015
Make EVGA Hydro Copper, dceightfive, Link, Date 29/06/2015
Make EVGA Hybrid, SaintJimmy, Link, Date 28/06/2015
Make MSI Gaming, Spokwiththeears, Link, Date 28/06/2015
Make Reference, goochinbuda, Link, Date 28/06/2015
Make Inno3D X3, Newu_boy, Link, Date 28/06/2015
Make MSI Gaming, Wyrdo, Link, Date 28/06/2015
Make MSI Gaming, gt11, Link, Date 27/06/2015
Make Zotac AMP Edition, DBT85, Link, Date 27/06/2015
Make Gigabyte G1, Rivod, Link, Date 27/06/2015
Make MSI Gaming, Milky1, Link, Date 27/06/2015
Make EVGA SC ACX, fornowagain, Link, Date 27/06/2015
Make Zotac AMP Edition, Angerer, Link, Date 27/06/2015
Make EVGA Hybrid, alexp999, Link, Date 27/06/2015
Make MSI Gaming, ubersonic, Link, Date 27/06/2015
Make MSI Gaming, lnoton, Link, Date 27/06/2015
Make Zotac AMP Edition, Type_R, Link, Date 27/06/2015
Make Reference, Wrxengland, Link, Date 27/06/2015
Make Zotac AMP Edition, agt, Link, Date 27/06/2015
Make EVGA SC ACX, Scramz, Link, Date 26/06/2015
Make Inno3D X3, Cavallino, Link, Date 26/06/2015
Make MSI Gaming, LauraLC, Link, Date 26/06/2015
Make Reference, Winnter, Link, Date 26/06/2015
Make Reference, Clov!s, Link, Date 26/06/2015
Make MSI Gaming, titaniumx3, Link, Date 26/06/2015
Make Zotac AMP Edition, PowerPie5000, Link, Date 26/06/2015
Make EVGA SC ACX, thefogo, Link, Date 26/06/2015
Make Zotac AMP Edition, mufc802, Link, Date 26/06/2015
Make EVGA SC ACX, GeneralD, Link, Date 26/06/2015
Make Zotac AMP Edition, Rossi~, Link, Date 26/06/2015
Make MSI Gaming, tyler_jrb, Link, Date 26/06/2015
Make Zotac AMP Edition, picnic, Link, Date 26/06/2015
Make MSI Gaming, DeanT77, Link, Date 26/06/2015
Make MSI Gaming, Brutos, Link, Date 26/06/2015
Make Zotac AMP Edition, Buck890, Link, Date 26/06/2015
Make MSI Gaming, se_vietboi, Link, Date 26/06/2015
Make Reference, Cottee, Link, Date 26/06/2015
Make EVGA SC ACX, ZeroG, Link, Date 26/06/2015
Make EVGA SC ACX, clone, Link, Date 25/06/2015
Make MSI Gaming, GiB, Link, Date 25/06/2015
Make Inno3D X3, rootz, Link, Date 25/06/2015
Make Inno3D X3, Khorvos, Link, Date 25/06/2015
Make Reference, amigafan2003, Link, Date 25/06/2015
Make Inno3D X3, theor14, Link, Date 25/06/2015
Make Inno3D X3, rickyjb, Link, Date 25/06/2015
Make Reference, floatindolphin, Link, Date 24/06/2015
Make Reference, eviljester91, Link, Date 23/06/2015
Make Reference, KillBoY_UK, Link, Date 23/06/2015
Make Gigabyte G1, Kered_Dub, Link, Date 23/06/2015
Make Gigabyte G1, Wrinkly, Link, Date 22/06/2015
Make Gigabyte G1, ronnie136, Link, Date 22/06/2015
Make Gigabyte G1, WHAT21A, Link, Date 22/06/2015
Make EVGA SC Ref, Divine Pain, Link, Date 22/06/2015
Make Gigabyte G1, AhadielGames, Link, Date 22/06/2015
Make Gigabyte G1, Shivji, Link, Date 20/06/2015
Make Reference, M1keMK, Link, Date 18/06/2015
Make EVGA SC ACX, ihatelag, Link, Date 18/06/2015
Make Reference, Diuz, Link, Date 18/06/2015
Make Reference, C3PO, Link, Date 18/06/2015
Make Reference, psychas, Link, Date 18/06/2015
Make Reference, MasterOC, Link, Date 18/06/2015
Make EVGA SC ACX, Malesu, Link, Date 17/06/2015
Make EVGA SC ACX, Mayh3M, Link, Date 17/06/2015
Make EVGA SC ACX, IT Troll, Link, Date 17/06/2015
Make EVGA SC Ref, jetpaczx, Link, Date 17/06/2015
Make Gigabyte G1, youdsy, Link, Date 17/06/2015
Make Gigabyte G1, HidYn, Link, Date 17/06/2015
Make Gigabyte G1, Matthew89, Link, Date 17/06/2015
Make Gigabyte G1, delpy8, Link, Date 17/06/2015
Make EVGA SC ACX, Axekickjack, Link, Date 17/06/2015
Make EVGA SC ACX, ArnieRambo, Link, Date 16/06/2015
Make EVGA SC ACX, agnes, Link, Date 16/06/2015
Make EVGA Hydro Copper, Giggz, Link, Date 16/06/2015
Make EVGA Hybrid, Muska, Link, Date 16/06/2015
Make EVGA Hybrid, is149, Link, Date 16/06/2015
Make Reference, The Mad One, Link, Date 15/06/2015
Make EVGA SC ACX, Valenni, Link, Date 15/06/2015
Make EVGA SC ACX, OldBoy75, Link, Date 15/06/2015
Make EVGA Hybrid, shiver, Link, Date 14/06/2015
Make Reference, ICEx21, Link, Date 14/06/2015
Make Reference, varkanoid, Link, Date 13/06/2015
Make EVGA SC ACX, JunglistE, Link, Date 13/06/2015
Make Reference, Gripen90, Link, Date 12/06/2015
Make Reference, Strife212, Link, Date 11/06/2015
Make Reference, saintdefender, Link, Date 11/06/2015
Make Reference, crazy8s, Link, Date 10/06/2015
Make Reference, Tom Martow, Link, Date 10/06/2015
Make Reference, rpggamesplayer, Link, Date 10/06/2015
Make Reference, toon_mad, Link, Date 10/06/2015
Make Reference, jjgreenwood, Link, Date 10/06/2015
Make Reference, Razor Time, Link, Date 10/06/2015
Make Reference, SeeNoWeevil, Link, Date 10/06/2015
Make Reference, RyanF, Link, Date 09/06/2015
Make Reference, roozor, Link, Date 09/06/2015
Make EVGA SC ACX, perosus, Link, Date 09/06/2015
Make Reference, ZombieDescartes, Link, Date 09/06/2015
Make Reference, Techen, Link, Date 08/06/2015
Make Reference, Rap1D, Link, Date 06/06/2015
Make Reference, khemist, Link, Date 06/06/2015
Make EVGA SC Ref, ciggybumly, Link, Date 05/06/2015
Make EVGA SC Ref, N19h7m4r3, Link, Date 04/06/2015
Make Reference, queeg, Link, Date 04/06/2015
Make Reference, abaddon, Link, Date 03/06/2015
Make Reference, Volv, Link, Date 03/06/2015
Make Reference, Larcwide, Link, Date 02/06/2015
Make Reference, a66as, Link, Date 02/06/2015
Make Reference, Angst, Link, Date 02/06/2015
Make Reference, RichardH754, Link, Date 02/06/2015
Make Reference, Phixsator, Link, Date 01/06/2015
Make Reference, Tommy_Here, Link, Date 01/06/2015
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your 980 Ti.​
