How to remove spray paint from plastic?
As I suspected but he could have taken you seriously because you forgot to add the :p
I hoped it was that obviously a bad idea I didn't need to!
Weirdly someone mentioned napalm...without lighting it it probably would work! Might leave the plastic quite brittle though.
If the surface wasn't sanded beforehand, a karcher jet washer (or similar) will strip it in seconds.
Or a wallpaper steamer! that would make the paint peel off, just don't leave it too long or it will look like you used plastic eating thinners! without having to chase the part across half the country once the pressure hits it :p
The plastic will be some form of abs.
Stick it in dot4 brake fluid for 24 hours and the spray paint will fall right off.
