I'd be real careful about using or not even bother using thinners unless you want a small pile of grey goo instead of your PS1.
Nooo! It'll be fine!
How much sprayed paint and associated chemicals have you worked with?
As I suspected but he could have taken you seriously because you forgot to add the![]()
If the surface wasn't sanded beforehand, a karcher jet washer (or similar) will strip it in seconds.
Dettol is what people use for stripping the paint off of warhammer miniatures etc. That may work depending on the type of paint.
