If you mind then complain to hr for equal treatment
Complaining to women about women not pulling their weight
You tell me would it be wrong then to fire the women for her less productivity, as any similar man doing less work would be. If a women is let go immediately in this sort of instance it is a problem because she is a women and firing her because of not enough output would be sexist. Do you think that is reasonable? Maybe the employer just wants someone to do a minimum of 500 bricks and the women can't do it.
Well it is a trick question because there are no female brick layers.
But it is still a good example because it uses individual units of work. I could have easily said x number of widgets at a factory.
The point is that feminists want it both ways. They want pay to be based on individual merit and gender must be ignored (which is reasonable), and they want it to be based hypocritically on gender (ie women want to be paid more solely because men are paid more) not individual merit. Can't have it both ways.
If women are to be paid more only because they are a woman and not based on individual merit, then men should be compensated as a group for doing more work.
They would be discaplined a cording to the companies performance rules.
It wouldn't be sexist it would just be for not performing in their role.
We have men and women in our factory, if you don't make your hours a manager had a word if it happens regularly you start on the disciplinary procedure if it doesn't improve and you got through all the stages and there isn't an underlying problem then it's out the door.
Gender doesn't come into it
Anything and nothing, some would imagine.? What is that quote meant to mean?
Source to studies please.
Male infants show a stronger interest in mechanical objects, while female infants show a stronger interest in the face.
I am not talking about making your hours, i am talking about productivity. It would be considered gender discrimination to fire a women who does her hours but due to physical or technical or pragmatic reasons does not perform her duties as well as her male counter parts in terms of productivity statistics. You can't fire a women because she performs less than her male counter parts legally speaking.
It was a whimsical pervade to [TW]Fox's predetermined biological role-play, in vein to another poster![]()
i don't mind, but people were mentioning that women don't do less in jobs, i know that women do do less at my place, and mentioned it. It was brought up at a meeting previously and people just said it wasn't worth the hassle to change it.
Then I'm glad clarity was sought.Really it sounded like you were saying only humans fight
So am I in our factory each job has a set time for doing it it's our productivity measure ie "number of bricks" (say fitting each part gets you half an hour you need to fit enough to = 80% the number of hours you're paid for)
And yes you can fire any member of staff for not meeting production standards their gender isn't a factor.
Sorry, as an extension to that statement, I know that it does but I was under the impression it requires other things that weren't see as an option in the past.
1. Existing laws being broken.
Women being paid less for the same job, in the same company with the same productivity - due to sexist decisions made by those higher up.
This is very straightforward & should be addressed right away.
This isn't about pay point but....
For example if I was a riot cop and an aggressive mob are approaching me, I wouldn't feel safe with a woman at my side.
Ok you tell me, is it fair for say a female brick layer to put up 250 bricks within a shift and a male brick layer to put up 700 bricks in a shift but they get the same pay because muh equality?
This is a counter question to the op. Should women be paid the same regardless of their productivity just because they are a woman? If it does matter then gender is irrelevant and people should be paid based on their productivity/merit/value to the employer.
How is it fair on the police man or fire man that always has to do the heavy lifting or work the worst shifts?
The fitness test is lower for females, therefore they do less prolonged foot chases, foot patrol, use of force for long periods of time, apprehension of fighting/struggling suspects, moving/pushing objects. Science!
Obviously for one off events, but if it's systemic across a company against a wider trend then it would be a cause to examine further to determine if there is anything amiss.that isn't always straightforward - you could maybe show it is likely happening in a large organisation where you've got a large sample and can demonstrate there is a significant difference
but with a smaller sample you'd expect people, whether male or female, to earn rather different amounts in some fields - if someone who happens to be female earns less than someone who happens to be male in the same role despite having the same level of experience and similar productivity that in itself isn't evidence of sexual discrimination - that situation can happen in spite of gender
The issue with the gender pay gap is far more complex than a simple average. For one, we can't look at a high level figure & derive any meaning from it at all - first it needs to be split by tenure in a role, the pay for the role & performance.
I'd split the whole subject in a few ways.
2. Encouragement for both men & women to not be put off certain professions by gender stereotypes.
This again, it's not highly controversial - pre-existing biases & pressures to avoid or go into certain professions should be broken down & people encouraged to work in whatever field they can excel at.
3. The perceived value of certain professions.
I would say, that nursing, carers, cleaners & other at times difficult & often demanding roles do deserve higher pay - there is I'd say a level of historic bias resulting in these jobs being perceived as 'women's jobs' & therefore less worthy of higher remuneration.
By addressing this alone, we are likely to see a closing of the gap to some degree.
4. Separating those who take time out to have a child, from those who want to work part time.
I do believe society should be accommodating to women who take time off to have children regarding career progression, I'd also extend this to men who adopt or anybody who is the primary care giver for a child (it could be offered to the man or women - this should be a choice made by the family).
On the other hand, we can't include this to extend to people who simply now wish to go part time - while they should be given the opportunity in existing roles to go part time (productivity isn't harmed much) - we can't expect progression to follow the same route of these individuals to have the same level of advancement. At a very basic level, in many companies some roles can't function on a part time basis & this alone is likely to result in a gender pay gap - but this is a justifiable difference.
Ham fisting a quota of people into senior positions I don't feel is the right way about it - it undermines merit in some cases & harbours resentment. The crux of the matter is a singular figure means nothing & we have to look far closer at the matter to understand the depth, scale & direction of the imbalance to avoid us falling into a series of amalgamation paradoxes.
