This is why I went custom loop over AIO. I check my fittings once a week to make sure they are tight, with an AIO you just hope they are tight enough. About 50kg of pressure to get them to come off. no d5 pump is going to do that.
+ there isn't any coolant going to peel away a PCB like that. If a leak occurred you could clean it up good enough to not notice any damage aswell. If a leak occurred with the system off it's likely everything would be ok.
I'm sure corsair would support you as this is no fault of your own.
In the future I would get an air cooler. Minimal chance of damage. I don't trust those AIOs personally. Definitely not now after seeing this...
