- 23 Mar 2011
Now recieved and processed at national hub! Does this mean fun time tomorrow? No ones home though so what do parcel force do?
Ok, so pretty much all my major issues with the Link have suddenly cleared up. Seems like each and every time I try and tinker with it, problems go away for god knows why.
Connecting fine now.
Audio works.
No problem switching back to cable TV input.
Soooo, now that I've finally had a chance to use it proper, it's pretty nice. Image quality isn't all that good, but it's not dreadful. I can definitely live with it for many games where I dont care about the graphics so much.
Performance is ok. Bit of occasional lag, but nothing that I think is going to hamper my experience with the games I'll be playing on it. Probably wont be playing much fast-paced competitive stuff with it.
Few issues with certain games:
- Cant run GTA V because a pop up from Windows asks me if I will allow it to change crap. I *really* hate this pop-up and wish there was a way I could turn it off for certain applications. I could run upstairs and hit Yes and then continue, but that's too annoying to deal with on a regular basis.
- Black Ops 3 is stuck in splitscreen mode trying to do Campaign mode. I'm guessing it's picking up both kb/m plus my 360 controller and assuming there's two people trying to play? Either way, it doesn't work properly.
- Trials Fusion, a Uplay game, will load up, but it wont display.
Blops 3 has an option to disable the second input in the control options.
Devs say 5.1 is in the pipeline.
I had the same thing. They failed the delivery, I went on their site and arranged to pick it up next day from their depo (free). Other options were a free redelivery next day at the same address, about £5 to have it delivered to another address and £1 for it to be dropped off at your local post office depo.
tracking says delivery attemlted now so ive missed it too!
sorry i could not find it, any help
didnt even see a control option ?
http://www.parcelforce.com/receiving/parcel-delivery
You should be able to sort something to get it tomorrow instead then. Unless they were kind enough to leave it with a neighbour.
Having trouble with mine. I can't get any kind of decent image quality with GTA V, it just looks a blocky mess![]()
MGS V looked okay, but the edges of textures look a bit weird - I don't know if it's the Nvidia encoder or if the TV is doing it as it's being upscaled from 1080p to 4K.
Brilliant. Sandwiches for you.So go into the menu, hit controls (it's the huge picture of a keyboard!), and go to the "Gamepad" tab:
Under "Split screen" there'll be an entry in there for the xinput (control pad) for player two. Disable it and you'll be good.
you'll most probably need active repeaters for both the hdmi and usb but yeah sure it'll be better if you can do it.
Active repeaters couldn't you just route it neatly down the stairs etc as log as you tack it so it can't be seen. The USB cable would end in a hub. I imagine this would be lag free and show uncompressed
both hdmi and usb can be hit and miss at that sort of length. I used to have my pc on the other side of the room to my desk and monitor. i length around the room was 15m give or take. I just got away with hdmi but i needed a usb repeater in the middle of the usb run otherwise it didnt work at all. your mileage may vary.
