i am now a father
I am on the Xbox One
A what?! Who allowed this..
All good here, and snap, my tag is g0rd so add me up or ping me a message when you're on.
i am now a father
Few tips for you;
Don't bother buying stuff from vendors at your light level, just rely on what drops you get as they'll keep on increasing as your light level increases.
Greetings Guardians! I'm a daily reader of this sub for staying up to date on this game, but I have never posted anything of my own.
As you all may know, last week we were made aware that we still have not discovered the proper utilization of 3oC.
I think my fireteam may have found it.
After some thorough testing over the weekend, along with the help of fellow guardians learning the true nature of the Three of Coin tarot, we believe that there is a direct relation with the vanguard strike streak to our precious 3oC. This method has given us 9 exotics out of 10 coins used.
Here are the steps...
Make sure that you do not have the 3oC buff active (kill a ultra if you do)
Load into the vanguard strike playlist (Heroic strikes seem to work as well)
Complete two strikes without 3oC
On the beginning of the third strike (once you have loaded in, and are on the ground) activate a Three of Coin and proceed the strike as normal
Killing an ultra has given us a 90% chance of an exotic
Exit back to orbit and return to the playlist
EDIT: A clarifying answer: if the third strike is dust palace, complete it and pop the three of coin on the forth strike and we also received an exotic, you can do this solo or with a partial fireteam. We Did experiment with popping the ToC too early (at the end of the second strike), this resulted in no exotic while my friend who was running the strikes with me popped his at the beginning of the third resulted in an exotic for him.
I need more data, guardians, help me out, go get some engrams. Disprove me if you can!
It's dark out there Guardian, go bring us back the light.
edit: Spelling, formatting, added step 6.
Worth a try, but I'm skeptical.
Has anybody managed to get the daily heroic to actually award anything for completion today?
A[L]C;28800823 said:Suros PDX-45 available at the gunsmith this week. Meant to be the same as the hawksaw
Yep - Just wait until he sells the god roll...
Does anyone know if the PDX-45 has the annoying pull to the left? It's seems to be pretty endemic of the Hakke pulse rifles, but not sure if it also affects the Suros.
