They are down to £273 now which makes them appealing.
This is also good news for us on x99, means the six core broadwell-e cpu's may come in at sub £400 at launch!
This is getting silly now, where are people getting there (bad) information these days.....
Some x99 boards come with usb 3.1 and multiple m.2 ports!! And with those 'empty' PCI -e lanes you can add even more io and drives.
Usb 3.1 is not native to z170 (or x99) it can be added by another chip by a motherboard manufacturer
http://m.hardocp.com/article/2015/08/12/intel_z170_chipset_summary#.VkcrFUZFDK0
X99 with usb 3.1 on board
https://www.overclockers.co.uk/asus...cket-2011-ddr4-atx-motherboard-mb-652-as.html
Z170 Boards with no USB 3.1
https://www.overclockers.co.uk/asus...cket-1151-ddr3-atx-motherboard-mb-644-as.html
https://www.overclockers.co.uk/asus...cket-1151-ddr4-atx-motherboard-mb-645-as.html
X99 with Dual m.2 slots
http://www.asrock.com/news/index.asp?id=2315
Cheap z170 boards may cost less then the cheapest x99 boards but they have less features. Look for boards with more feature parity and you will find they cost about the same!!
Even at £273 for the 6700k its still worth looking at an x99/5820k combo due to the extra cores (you'll be stuck with four on z170) and better upgrade route to broadwell -e (kabylake will be a pointless upgrade from skylake unless you intend to use an igpu)
). Sorry I didn't mean to start a war, I only said X99 because of the extra cores and the cheaper price. Haha
wow buddy, do you really have to defend every post that is anyhow damaging team x99. I own a x99 platform and a z170 platform, and i have no favourite, its your PC, not your new born baby lol.
Why would you compare the cheapest z170 board with a mid range x99 board and expect it to have similar board features (specifically USB 3.1 as you stated)
x99 board represents a decent feature list compared to...
https://www.overclockers.co.uk/asus...cket-1151-ddr4-atx-motherboard-mb-647-as.html
which is the Z170 equivalent in terms of brand and factory build quality.
£117 vs £210, clearly not the same
My point is the price per feature, a mid range (~£120) z170 board has all features an average user will need, i.e. 1x 16X GPU slot, 1x m.2 Gen3 X4, usb 3.1 (type-c), (and SATA-e maybe).
Try find a x99 motherboard for £120 with all those features.
Some people may see the value of the extra PCI-E lanes, quad channel RAM etc and I have no problem with that.
Your changing your story now..... you claimed that z170 had more features (like m.2 slots and usb 3.1) than x99. A totally untrue statement as I pointed out.
Usb 3.1 is not native to the z170 chipset (or x99) it can be added via a motherboard chip or expansion card. X99 motherboards can and do have (multiple) m.2 slots. Are you sure you own a x99 setup as you seem pretty poorly informed re what the chipset does and does not offer...
I was not comparing the z170 board and the x99 on price the headings are quite clear to show that you can buy x99 boards with usb3.1 and z170 boards without, to demonstrate that your claims if z170 boards having more features was nonsense and entirely dependant on the individual board being purchased. I am obviously a little biased towards x99 but mostly I have found a lot of people have been talking an awful lot of nonsense about z170 and x99 of late....
Re the price situation ocuk don't have the largest selection of x99 boards and but I can buy a board or comparable spec to the z170 elsewhere for £160 odd still more expensive but depending on what happens to the price of the 6700k going forward potentially still cheaper as a package
.http://i.imgur.com/lg3M6kC.png x99 motherboard
http://i.imgur.com/acxxo22.jpg
http://i.imgur.com/P0bRAi9.png?1 old picture of z170 build in same case
Come on m8y, I've been around for a while and defiantly not the type to boast for e-pen. Again I have no problem with any opinions (bias or not).
Maybe i got the wording wrong (i.e. 'feature-rich') but there is no need to go forum police. I still standby my opinion on mid-range z170 boards represent decent value. Why can't you accept other people can have other opinions.
I'm going to step away, it is a boring Saturday afternoon but i'm sure i can find something better to do then getting sucked into this any further.
To me z170 motherboards is clearly more feature-rich. I much rather have usb3.1, m.2 etc etc... than empty pci-e lanes on my motherboard
My only issue with recommending the 5820k would be the reports of USB and memory channel failures. A colleague is looking for a new PC as his apparently 'fogged' his room (quite literally) when he turned his on after a week's absence. He is now trying to chose between 5820k and 6700k (at present).
I am also concerned that the lower clocks on the 5820k would put it at a disadvantage as he has no interest in SLI/Crossfire.
