I emailed them this week, they should be getting them tomorrow if they have no issues at customs![]()
That will make my week!!! Bargain for the price I have to say.
For those of you who want the Aromamizer or just fancy a second, FT now have a listing for the Authentic tanks: £17.81 for the 6ml...
https://www.fasttech.com/products/1/10018387/3799301-authentic-steam-crave-aromamizer-rdta-atomizer
Ships in 7 business days.
Appears to be the Triple post deck though![]()
6ml / glass + stainless steel / 2-post version
Should be the Velocity style deck.
The top description says two post but the main description shows:
"Standard triple posts built-deck to build single coil or dual coil"
So not sure which will ship.
Erm, you need a coil or RBA section to pull the two halves together?
I'd screwed a new coil into the top half earlier and the pyrex still came away, so I though something was wrong. It didn't occur to me that the coil threads at both ends. I hadn't taken notice properly when I unscrewed the used coil. What a dumbass
All working fine now.Check my video. Are my white and black o-rings not seated correctly? I just can't get it tight at either end.
