Looking at the images it still has only two dish connectors unless I missing something, so I wonder how they're managing to split the signal into 5 for Sky Q silver? I hope this doesn't mean further compression of image quality.
Where have you got that from? The OP with the info from Sky's website even says watch 5 different channels and record 4.
It uses a wideband lnb similar to idea to a communal system
Sky Q that blends live and on-demand TV
do they say it will all be sat based?
It just seemed like you were guessing. filter2000 has an answer that it's using a wideband LNB, so 'engineer' install as opposed to self-install. The barriers to adopting multi-room are massively reduced now though.
Packages star at £200 a month plus £50 a month for UHD, i won't be far off![]()
Can`t see see the average person upgrading to Sky Q or 4K
 But i suspect the costs will, initially, be pretty ridiculous especially for the full monty, ie - Sky Q Silver box etc.They still insist on the DVR being in your house instead of on a pool of storage they control centrally....
