- 10 Nov 2006
- Lincolnshire
Check the 21:9 forums on google ive used their tweeks and it looks fine now
Getting tempted to order one of these nowDo movies and TV series fill the screen?
I've had a bit of time with my X34 Gsync, so far:
The Not So Good:
- Not as tall as my Dell 30"
- Only overclocks to 95Hz but I've yet to reset it to see if it solves it.
- The menu buttons are abysmal.
- As the menu is such a pain and the OSD timeout catching me every time, the first thing you must do is change this to 30 seconds or something....
- The curve takes a lot of getting used to. Games are fine but when in windows everything is bent, not curved, if you get my understanding. You could never image edit on this monitor, you'd go crazy. I'm trying to work out the best way to sit in front of it to minimise the curvature, haven't managed it thus far. Look up - bent, look down - bent!
Other things to note, since the menu buttons are so bad, a remote would have been a good idea for things like changing the volume or input source.
Despite saying that I would never buy an acer product, I might just buckle if the price of the freesync drops to £600 some time soon.... And from what I have read, the freesync version doesn't seem to have any issues except possibly bad backlight bleed?
Yeah that isn't bad at all for 80% brightness! A lot higher than what I would be using!
On my 29um65, I can't use anything over 13% as it is way too bright for me.
i followed the settings from the tweaktown review, brightness is at 58 and everything looks pretty much spot on to me so kept them
