headd @ overclock.net | Posted 28th October 2015 said:
Also use Frame times and comparable FPS as primary. Fraps is here just for min FPS.
Test system:
2500K 4.5Ghz
8GB 1600 8-9-8 1T
GTX970 1500/8000
win7 64
6700K 4.5Ghz
16GB 2937 CL15 1T
GTX970 1500/8000
win7 64
Watchdogs-1920x1080 all max SMAA temporal. Testing method is driving in city2500K fraps log-Avg: 58.942 - Min: 40 - Max: 87
http://abload.de/img/watchdogs60ss0.jpg
6700K fraps log Avg: 82.677 - Min: 73 - Max: 91
frame times and comparable FPS
http://abload.de/img/watchdogspcs0r.jpg
Skyrim+Mods
2500K 38.2fps http://abload.de/img/tesv_2015_08_25_13_17tmsse.png
6700K 56.3fps http://abload.de/img/tesv_2015_08_25_19_150asse.png
World of tanks-all max 1920x1080 + FXAA.Kharkov map replay
2500K fraps log Avg: 83.136 - Min: 62 - Max: 101
http://abload.de/img/wotimsfx.jpg
6700K fraps log Avg: 112.393 - Min: 87 - Max: 126
http://abload.de/img/wotuwsr4.jpg
Crysis3-all max 1920x1080 + SMAA. Test method2500K fraps log Avg: 50.839 - Min: 38 - Max: 78
Screenshot at same place http://abload.de/img/crysis3_2015_08_19_04wus7z.png
http://abload.de/img/crysis3ymsyk.jpg
6700K fraps log Avg: 77.112 - Min: 72 - Max: 82
screenshot at same place http://abload.de/img/crysis3_2015_08_25_214vsvw.png
http://abload.de/img/crysis3a6shb.jpg
GTA5-all max 1920x1080 + 2xMSAA.Advanced settings all max. Test method is driving in city2500K fraps log Avg: 59.276 - Min: 48 - Max: 68
http://abload.de/img/gta5vesy4.jpg
6700K fraps log Avg: 65.094 - Min: 51 - Max: 77
http://abload.de/img/gta5twssx.jpg
Far cry4- 1920x1080 Ultra. Test method is when you leave pagan ming palace until car crash2500K fraps log Avg: 81.496 - Min: 55 - Max: 99
http://abload.de/img/farcry47vspp.jpg
6700K fraps log Avg: 86.963 - Min: 70 - Max: 106
http://abload.de/img/far4gvstl.jpg
Witcher3- 1920x1080 all max.Hairworks off,DOF off. Test method2500K fraps log Avg: 58.565 - Min: 46 - Max: 71
http://abload.de/img/witcher306sa8.jpg
6700K fraps log Avg: 67.163 - Min: 58 - Max: 77
http://abload.de/img/witcher3knsip.jpg
Dying light-1920x1080 all max. Test method same like here to 1:50 time2500K fraps log Avg: 72.068 - Min: 53 - Max: 87
http://abload.de/img/dyinglightivsdi.jpg
6700K fraps log Avg: 74.457 - Min: 57 - Max: 89
http://abload.de/img/dyinglightnns7w.jpg
headd @ overclock.net | Posted 28th October 2015 said:HT ON/OFF its same.Only in crysis3 and watchdogs are differences.Its GPU bottleneck with skylake.(skylake is too strong for GTX970 even with HT OFF)
i7 6700k 4.6Ghz
3000Mhz DDR4 CL15 1T
GTX970 1500/8000
Same test method
CRYSIS3 HT OFF
Foto
http://abload.de/img/crysis3_2015_08_27_21xeja3.png
Fraps FPS Avg: 62.620 - Min: 51 - Max: 79
Frametimes fps
http://abload.de/img/crysis3fdkzc.jpg
CRYSIS3 HT ON
Foto
http://abload.de/img/crysis3_2015_08_27_17t9krr.png
Fraps FPS Avg: 75.393 - Min: 71 - Max: 80
Frametimes fps
http://abload.de/img/crysis3wdkb9.jpg
Watch dogs HT OFF
Fraps FPS Avg: 77.327 - Min: 59 - Max: 93
Frametimes fps
http://abload.de/img/watchdogswojtv.jpg
Watch dogs HT ON
Fraps FPS Avg: 84.063 - Min: 73 - Max: 93
Frametimes fps
http://abload.de/img/watchdogspfk0v.jpg
Witcher3 HT OFF
Fraps FPS Avg: 68.359 - Min: 59 - Max: 77
Frametimes fps
http://abload.de/img/witcher34wkjd.jpg
Witcher3 HT ON
Fraps FPS Avg: 68.776 - Min: 59 - Max: 79
Frametimes fps
http://abload.de/img/witcher3jnks4.jpg
Skyrim HT OFF
Foto
http://abload.de/img/tesv_2015_08_27_22_13zukbx.png
Skyrim HT ON
Foto
http://abload.de/img/tesv_2015_08_28_03_44krkc8.png
GTA5 HT OFF
Fraps FPS Avg: 65.847 - Min: 51 - Max: 75
Frametimes fps
http://abload.de/img/gta5rvk2q.jpg
GTA5 HT ON
Fraps FPS Avg: 65.425 - Min: 53 - Max: 75
Frametimes fps
http://abload.de/img/gta5zsk3p.jpg
Far cry4 HT OFF
Fraps FPS Avg: 89.517 - Min: 74 - Max: 109
Frametimes fps
http://abload.de/img/farcry4x5klr.jpg
Far cry4 HT ON
Fraps FPS Avg: 89.640 - Min: 77 - Max: 107
Frametimes fps
http://abload.de/img/farcry4fnksw.jpg
Dying Ligt HT OFF
Fraps FPS Avg: 74.300 - Min: 57 - Max: 93
Frametimes fps
http://abload.de/img/dyinglightgvjzg.jpg
Dying Light HT ON
Fraps FPS Avg: 74.146 - Min: 56 - Max: 92
Frametimes fps
http://abload.de/img/dyinglighth9jqs.jpg
WOT HT OFF
Fraps FPS Avg: 110.366 - Min: 83 - Max: 124
Frametimes fps
http://abload.de/img/beznzvultj97.jpg
WOT HT ON
Fraps FPS Avg: 110.002 - Min: 84 - Max: 123
Frametimes fps
http://abload.de/img/wotvzjdn.jpg
Yeah no point, it's better to blow the cash on a better GPU if you are at 1440P or higher.krooton said:Safe to assume that a 2700k wouldn't have as big a difference then, looks like I am good until 7th gen![]()
Raw power, but the difference does not seem really worth it for gaming. Maybe when AMD / Nvidia release next gen mid-range / higher end cards next year.Michaeljcox24 said:So is it the threads or the raw power that's making the difference? I thought games only used the 4 ?
I upgraded a few weeks ago from i5 2500k at 4.2ghz to skylake 6600k at 4.5ghz. And yes it is noticebly quicker unpacking zip files etc. The main reason i switched to the z170 setup was to upgrade my harddrive. I had a 2tb samsung spinpoint and now i have the samsung 256gb m2 951. Its amazingly fast!!!! Go for it i say
I read somewhere that in gaming terms, you can get a 25% increase in FPS by making this jump. Has anyone done it? Not getting performance issues as such (GTX980) but the cpu is getting a bit long in the tooth now.
Thanks.
Isn't this a best case? If you run a higher resolution and most on here seem to, you'll be held back by your GPU. Crysis 3 I understand isn't very well optimised and requires more cpu grunt to get the best out of it.
Also seems odd there is such a difference between the 6600k and 6700k when usually there isn't much of a gap between an i7 and an i5 for gaming...
I went from a 2600K to a 6600K (because of a system fault), but have yet to assemble the system. The i7 is simply too overpriced, otherwise I would have gone with it.
I went from a 2500k@ 4.8 to a 4790k@ 4.6. While I never know what fps I get in games (never checked) I could actually see a big improvement in arma 3. Im sure also upgrading from 670sli to titan black sli helped, but arama3 is a more cpu intensive game.
Is that using the IGP? I don't understand why Broadwell would be faster than Skylake otherwise.Here's another game, if you believe crysis 3 to be unoptimized;
Increasing the resolution will narrow the difference in FPS a little, though as 1080P is still the most common resolution, it's still the most important result for the masses.
