No its a - sign
Yes try normal and if you keep pressing that key it should go to a plus sign.
ok will take a look
Yes your right its right at the bottom then turns to
+ .Okay I'm on Normal now . Should i run some tests
Tell me about it. I always get it wrong
, but if someone else buys this board they will know what to for overclocking now.No ones going to buy this board anytime soon
how do i save them readings so i can show you
No VR T1. It seems to be running everything slower now i set it to Normal and its getting much hotter
