it does. I was really wanting the red phanteks to match my motherboard and case but if I hadn't won it the NH-D14 or 15 was my next optionThe Noctua NH-D14 seems to come in a little cheaper
Yea there a fair chunk of a thing but the results speak for themselves. As I say it does a better job than the H80i and gives me piece of mind. And I must admit I actually like the look of it.. I'm tempted to try and get the raised lettering painted silver or black so it stands outGod it looks so big
It sure does £22 is a nice saving. Does it clear your ram slots okay ?
I've got the NH-D14 and it's huge, but gets the job done. It just depends if you like the Noctua beige/brown colour scheme on their fans. Performance wise, I can't complain and for something that big, it was very easy to install.
Humax your ram is low profile so will fit with most coolers, unless its 1 which lays flat and is long.
This one, it is big but quiet and very efficient with a 38mm x 140mm fan at low rpm. It does not cover the Ram slots either.
https://www.overclockers.co.uk/silverstone-sst-he01-heligon-cpu-cooler-hs-005-sv.html
Im running a FX-8350 at 4.4Ghz and its only hitting 43C. Had some temp problems but this sorted it all out. The thread is here
http://forums.overclockers.co.uk/showthread.php?t=18703391
