I use cmd-top left to put the display to sleep and that still works for me.Anyone else notice since 10.11.1 that hot corners no longer work for Screensaver?
. Downloads fine then gets stuck at "installing".
.Anyone else struggling with Xcode 7 on it?
Seems to have screwed up all the settings and now I can't get it to reinstall. Downloads fine then gets stuck at "installing".
Really wish they wouldn't insist on the latest Xcode even when targeting previous versions.
Starting to lose my mind this project is way overdue.
I tried online and using the 7.1.1 dmg from the developer site.
In the end I rebooted (having not 'successfully installed') and it's 7.1.1.. seems there's something odd about it..
I agree - the apple cycling is actually causing a large amount of issues in terms of managing and getting higher costs and delays due to it. I just started using Storyboards last night.. nicer for the IB but still..
. On the plus side I can actually write code now
but it works
.The OS X El Capitan 10.11.2 update improves the stability, compatibility, and security of your Mac.
This update:
-Improves Wi-Fi reliability
-Improves the reliability of Handoff and AirDrop
-Fixes an issue that may cause Bluetooth devices to disconnect
-Fixes an issue that prevented Mail from deleting messages in an offline Exchange account
-Fixes an issue that prevented importing photos from an iPhone to a Mac using a USB cable
-Improves iCloud Photo Sharing for Live Photos
