Von, this is not normally an issue for me I just man up, but this year i am looking to go on some club rides over the winter and mudguards are mandatory. This might be the excuse I am looking for to order another bike N+1 and all that.
KINESIS T2.
Talking of Giants this seems like a lot of bike for not much money
http://www.rutlandcycling.com/284977/products/2015-giant-defy-3-road-bike-blue-white.aspx?
Part of the problem is that I don't religiously take my "preventer" inhaler. The last time I saw an asthma nurse she said that a large proportion of asthma ailments could be avoided through the use of the preventer inhaler.
So this happened:
https://www.strava.com/activities/438837948
My first time on a turbo trainer and omg it's hard. Like pedalling into a pretty strong headwind hard, but without the benefit of being kept cool by it. Perhaps my turbo (a donated one) is full of sand... should it really be that hard? The resistance is at minimum, and the unit is just held against the tyre by a spring.
Anyone with a smart trainer on zwift or anything else that can tell me if it feels more like being on a road? I don't like this for the hills (climbs) because I just slow down on the screen and it doesn't feel like being on a hill. Of course you can change the gears but then your cadence is all wrong.
It's just a manual/dumb trainer I have, with a garmin speed/cadence sensor connected via ant+ dongle.
KINESIS T2.
I just built one, can't knock it.
Although I haven't got any guards on it yet. SKS Chromoplastics the ones to get?
So this happened:
Hey Jono
I use a Wahoo Kickr with Zwift 4-5 times a week. At the moment though i'm going through a 12 week training plan so i'm using ERG mode all the time. I do occasionally resort back to 'normal' mode and I can tell you it does feel pretty realistic. Them hills I still have to crank it into 30/19-21'ish and it hurts big time. Have you got a fan going into your face/torso , get one it helps a lot.
I finished my training ride yesterday and had a couple of mates on so I did a lap with them afterwards. It was great while the front rider was using maybe 2.5-3 w/kg and us lot behind using the draft (quite realistic really) at maybe 2+ w/kg. Amazing to think a virtual ride with people across the world could be like this in real time.
Your trainer should have a certain resistance setting for Zwift I think , you may have to look it up (something to do with zpower). I'll add you on Strava if thats ok and we can maybe have a lap sometime
I haven't worked out how the social stuff works... maybe I need a smartphone app. No-one that only has one bike needs a Wahoo Kickr. If i were you I'd get a £150 turbo and a winter bike. Set the summer bike up on the turbo and leave it there until the weather improves then swap them over. A mate of mine who has far too much disposable income! bought a kickr and its great but my cycleops fluid 2 linked to trainer road gives just the same level of training. Seriously - save your money. Its a pain in the a*** swapping a bike in and out of a turbo and it can be another excuse not to bother.My trainer isn't listed in Zwift - it's an Elite Fluid Travel, I think. I chose Elite Fluid + from Zwift... it kinda looked similar, but I suspect this thing I am using is somewhat older than they were expecting.
No problem about Strava, followed you tooI haven't worked out how the social stuff works... maybe I need a smartphone app.
Would you recommend the Kickr? I know it's about as much as my bike cost, but given how much I want to be cycling, and improving, vs my motivation when it's cold/dark/damp before and after work... it may be a good investment.
It'd keep my winter bike cleaner (as it's my only/summer bike too) if I just got outside when it's not so horrific.
I think I definitely want a smart trainer though, even if it's a Tacx Vortex... but I quite like the idea of it being able to simulate 15% hills... that's mostly what I encounter, on my rides out.... though some are 20-25%+.... and they are evil.
SKS Chromoplastics are pretty much the best choice in terms of money, lightness and not sucking.
Finally got back on my bike monday. I'm a right fat (ter) pie having not ridden for over a month and just eating while traveling all month. It was a mission! I don't know where my legs have gone!?
Just picked up an Elite Muin Turbo for use with Bkool and Zwift. No excuses not to train now!
If you can fit them, yes they're one of the best! You should be fine for clearance on the TK2 Tom, probably even with the 45mm guards for your 28mm tyres although worth googling.
I do want a smart one....
35mm guards clear 28mm tyres on my (slightly later) T2
45mm guards wouldnt go through the frame, the 35s are close.
The point is - I just want to go on the TT when the weather is too horrible/dangerous to go outside on it, or I just feel like doing 10 miles or so.
Like Roady - I just want to do everything on the same bike![]()
Perfect info! I wasn't sure if the 35's would have enough clearance for 28's. Are they close width wise? Which tyres? I know on my 25's there's quite a difference between conti's and mitch.
I'm exactly the same, although I've ended up with a good 'do it all' and means rather than looking for a 'better bike for the summer' I'm looking at an 'equal/possibly-better bike for the winter' (disc brakes etc). My grand plan would then to have an even better bike for the summer at a later stage! Although that does mean I'd be left with my Defy 1 as a turbo bike...!![]()
Cool, let us know what you think of it! Which did you have before?
