I can see the beta access, it just wont kick off the download.
You have to buy the expansion to get a 64-bit client. Well that's a bit ****.If you see the 32-bit client in your launcher you can breathe a sigh of relief. This is the normal version of Elite Dangerous as the game has always been 32-bit.
We will be upgrading Elite Dangerous to take advantage of 64-bit architecture with the forthcoming release of Elite Dangerous: Horizons. The base game will remain 32-bit should you not wish to upgrade to Horizons.
Once Horizons is released all Commanders purchasing Horizons will be able to make use of the 64-bit version of the game.
You need to buy a vehicle bay in Outfitting and then you can buy Scarabs to put in it. However there 's an issue with the build deployment that might mean you're playing the wrong version - we're looking into it now.
Michael
You can't land on all of them?So I bought my planetary kit, the vehicle bay, and the srv...now how do I find which planets to land on.
Trial and error I guess
EDIT: there are indications on the system map
We need more screen shots when you're out on the surface!Just Landed![]()
