Still don't have the install option for this. is it supposed to automatically appear?
Click on Support in the menu of the Launcher. This will take you to the Frontier support page, where you can download the latest Launcher, in case yours isn't up to date. Remember to close everything (including the webpage) before doing the install.
It worked for a friend having the same issue last night.
The new launcher should now have everything, assuming you bought into the Beta and all.
Just looking at other ships but am not sure the Eagle is worth getting over the sidewinder
(can't seem to find any comparisons of agility which seems the main possible benefit?)
Each one on the shipyard page of stats has a 10-segment bar showing the manoeuvrability rating.
Eagle - 10/10
Sidewinder - 8/10
Viper - 6/10
Type-9 - 0/10!!
Those are the stock manoeuvrability scores, so beefing up will improve either ship.
The Eagle can be kitted out to do some pretty hefty damage - Three of those zooming around a Python can drop it in no time at all. I loved mine.
I have read that trading can be more lucrative so might save up for a trading ship.
Eventually, yes.
You need some savvy trade routes and a ship that can hold enough cargo though, or you'll end up spending more on just the fuel than you make from the trades.
Trading in Rare commodities is a good way to start.
Combat is more lively, though.
I'd suggest taking various different types of missions in your Sidewinder, upgrading your kit a bit and exploring all the different options - Mining, smuggling, combat, assassinations, cargo runs, data, exploration... See what you get on best with. Usually a combination/multitask will be the best to get you started, so something like hunting pirates in a RES or the USSes, while dropping in on WSSes and picking up stolen cargo, all on your way through systems (scan them for Cartographical data too) to complete missions...
Is there a favoured control method?
Joystick and Throttle (HOTAS) is the main one, I expect.
Got a range of choices, from £30 cheapy ones right up to the full monty, with rudder pedals and everything.
Should you be able to get exploration for every system? Or are some well known enough that you can't?
This is not my area of interest, but here's what I can tell you...
Generally, when it says Unexplored, that just means YOU haven't explored it yet. You can buy the system data when you use Galaxy Map (think you must be docked for this facility) if you prefer, in which case nothing will then be Unknown to you.
I always give the Disco scanner a charge up when I enter a system. This makes it go BLAAAAAAAAAAAGGHHHH and you find the Unknowns. Sometimes the scanner stays active, while other times you need to charge it again. Sometimes new Unknowns only appear when you get closer to them. Not sure how this part works, so I just keep charging it periodically.
You can scan each new Unknown and get the details as you've probably been doing so far. If you then take this a certain distance from that system, you can sell that data - It's something like a minimum 20Ly from source, so if you're going on a long journey, scan every new system you go through. I think the further away you take teh data, the more it's worth?
Is it as simple as: if there's nothing showing as 'unexplored' in the system, then you can't get data from anywhere in the system?
I believe so, yes.... although it's merely Unknown. If it's Unexplored, then scan away. If you are indeed the first to explore that system, it's worth more money and your name is down as the one who discovered it. If you discover an Earth-like system, it's worth even more money!!
However, I believe you lose all your data if you die before getting it all back to a station to sell it.
I expected to have to use my discovery scanner, but in some systems the moment I jump in I get a message to say some bodies are discovered. But then sometimes if I immediately use my scanner, it finds some extras.
This is the bit I'm not sure on - It seems to be passive or active, depending on when you last charged it... and I just haven't bothered to look up how it works in the forum/manual.
That's why I charge it periodically/on entering a new system.
Hopefully someone will offer better insight than I....
