Oh, wow, I thought the Zotac Splinter Cell promo ended with the 700-series.
Well, there's a code in the box for it! Can't believe how heavy this Zotac is!
It's here, with Haribo!
More than likely an unstable overclock.
Then probably a driver problem. Use the machine as normal and monitor it, see if there's a pattern.
OK cheers. Would you recommend a clean install of the drivers?
Won't do any harm. Do you run Afterburner? If so, uninstall AB, download the latest Nv drivers, click on custom install and run a clean install so it removes the old drivers before writing the new, then re-install AB if you use it.
Temps never exceed 35 degrees.
Thanks.
do you have the fan on 100 percent? that sounds too good to be true??
Hello folks, first post here after purchasing a few upgrades for my PC from OCUK.
Picked up an EVGA 980ti, EVGA SUPERNOVA G2 750w PSU, Noctua NH-D9L, 16GB FuryX Hyper RAM, Corsair 240 Air. Kept my SSD, HDD's, Mobo and CPU.
Looking forward to spending some time here, cheers.
Learn to reduce those images. They're just way to big.
And welcome to the forums and owners club.
Thanks, sorry, force of habit from posting on AV Forums!
Which code is best to use? I'll edit them when I get back, thanks.
I have a EVGA 980ti Hybrid. To overclock i've increased powerlimit to 110% and increased the GPU offset to +121mhz in EVGA Precision. Mem offset is +0. That gives me 1450 boost.
It seems stable in unigine but occasionally in gaming I get crashes to desktop with an error message saying display driver crashed and recovered or something like that.
Im assuming thats due to an unstable overclock? My GPUZ VDDC is 0.874v at idle and 1.199 on 99% load in valley. Temps never exceed 35 degrees. Do I need to overvolt it? If so do I drop the power target to 100% first? How much overvoltage is typically needed or safe?
Thanks.
