This game really is RAM hungry. I'm sitting at 0.8gb left between the game and my other programs.![]()
I've had it over 8Gb.Wow! Max ram usage I saw was around 6gb (including system etc) and that is on max settings at 1440p.
Does it instantly go to that or does it increase the more you play? I have read a few things about memory leaks and the sort
Anyone worked out how to change the FOV yet. It's doing my head in. Literally.
So....worth buying then?
My game has crashed once but has since been working fine. The RAM sits at 2GB usage without the game running, after playing the game for about an hour I check HWinfo and the Max physical memory used shows 6200MB (Max available 6700MB). So there's still about 500MB to spare.
I don't have much apos running in the background though (Fraps, Steam, HWinfo, Kaspersky internet security)
I think the game is VERY repetitive. It is the same thing over and over! It is still fun though. Played it quite a lot today and have a headache and a bloodshot eye because of it! I think?
Yes, it may be all about destruction by it really doesn't get repetitive which is great. Tbh I hardly use vehicles much more fun to parachute, glide and grapple around![]()
DId you not do any research before? are you new to the franchise?Just uninstalled it. Had enough of the repetitiveness!
