The biggest problem / flaw with TN is the vertical colour shift but in the whole scheme of things it's not really a problem when gaming at all.
Always![]()
Depends on the panel in question. A lot of the older TN panels looked very washed out in comparison with a decent IPS but these days with the introduction of 8 bit TN panels things have changed.
I went from an IPS display to the TN Rog swift and colour wise there isn't much in it. The IPS had slightly more saturated looking colours but it also had a much lighter AG coating which i think has more to do with it then the panel type. The swifts blacks are better in my opinion as there is no IPS glow and the response times/high refresh rate are fantastic. It still has poor viewing angles (which doesn't bother me as i view it head on) and vertical colour shift (which is noticeable and slightly annoying) but if i had to pick i'd take the swift over my old IPS every time.
It's a lot more than that in realistic testing.
Always![]()
If you want a 27" TN panel, gimme your IPS and you can have mine!!!Hmm, you're not selling it lol.
Are they gaming biased? I mean are they perhaps less of a wise choice if it's more of an all round monitor I'm after, rather than a specific gaming focussed requirement?
Thanks for the input, more than I expected TBH.
I think given that a) I'm more on the casual gaming side these days, combined with b) Not playing any sort of super cereal FPS games, has me leaning towards sticking with IPS. My usage is probably 50/50 between gaming and browsing/movie/TV show watching.
I just wish 1440p IPS g-sync was a more common (and cheaper!) thing. I guess I just wait and see what comes or take the plunge on one of the 1440p non g-sync IPS screens...
+100
My Dell 27" IPS on the Right never ever seems to get used anymore.
Am always using my TN ROG swift.
SNIP
I did clean it...Clean your desk, please!
