They're on the store on PS4, found it earlier
Aha fair enough, couldn't find them at all yesterday even in the early hours. They are all showing up for me now though! Cheers
They aren't for me. Even did a manual search for Dark Cloud. Its not there.
Eurogamer have done some analysis of these and have confirmed that there are regional differences to these new releases as they are actually based on the version of the game to release in each region. This means we will get the PAL version of the game.
In the case of GTA, the PAL version ran at 25fps compared with the NTSC version which ran at 30fps. When this is being played through the PS4 emulator it is forcing the PAL version to run at 30fps and it does this by blending frames together (basically creating new frames to make up for the missing ones) and in doing so it creates an unfortunate judder effect. It's not unplayable but it's far from ideal.
So essentially if you're thinking of buying any PS2 games it would be best to buy the NTSC version from a US PSN account. Fortunately there is no region locking.
If you buy it on the US store, do you need to play it through your USA account to get the benefit?
So these games only play at 50hz or at 25/50fps?
Fairly significant difference. One literally slows the game down, the other is just a lower framerate.
canadian store is better.
Can you play games bought from the American store on a UK machine?
Manhunt better be on the way too! that game was awesome.
