best (non root) adblocking solution on android
18 Mar 2010
I have previously used the adblock app on a non rooted phone, which only works when using WiFi with a proxy server. Other alternatives I am aware of include using the Firefox browser with the adblock add-on or using the adblock browser. Any other options? Which do you think is best?
Is the adblock browser safe? It asks for a lot of permissions.
Why do you not want to root it? Google don;t want you blocking adverts so it's difficult to do it effectively without a rooted phone.
netguard + hosts blocking https://github.com/M66B/NetGuard
Features:
Simple to use
No root required
100% open source
No calling home
No tracking or analytics
No advertisements
Actively developed and supported
Android 4.0 and later supported
IPv4/IPv6 TCP/UDP supported
Tethering supported
Multiple device users supported
Optionally allow when screen on
Optionally block when roaming
Optionally block system applications
Optionally forward ports, also to external addresses (not available if installed from the Play store)
Optionally notify when an application accesses the internet
Optionally record network usage per application per address
Optionally block ads using a hosts file (not available if installed from the Play store)
Material design theme with light and dark theme
