Caporegime
- 18 Oct 2002
Hi all, I'm new here and I'm with Club 3D. These adapters have been announced quite some time ago but issues with testing demanded a revision of the chip inside the adapters.
They are the first 'real' DP 1.2 to HDMI 2.0 4K60 adapters to hit the market and we start shipping on 30 December. If all goes well they should be in stock at OcUK in the first days of the new year.
If I can answer any questions or provide info on these products please let me know.
Rgds, RoyalKing, Club 3D
Can you confirm if they have full 4:4:4 Chroma / 24bit RGB.
I'm all over one if they do.
Okay for all you people who have big 4K tellies @60Hz
http://www.accellcables.com/products/displayport-1-2-to-hdmi-2-0-adapter
$37.99
I imagine they will be available soon (says out of stock so probably means not yet in stock)
If your requirements are that specific you had better be using DP with a DP monitor that also matches those specs.
Nothing terribly specific about wanting to output 4k to a TV without the colours getting messed up by chroma subsampling.
What us wrong with 10bpc with 4:4:4 ? Does your tv support 4:4:4 with 24, what model TV is it? Can the HDMI 2.0 spec even handle that?
Aye, I'm hoping that the DP part of the connection will have better signal integrity so I can run DP cabling as part of my connection to my TV. As I've found I cant get a reliable full chroma 4k60Hz connection over a 5M HDMI cable, and I have tried quite a few.you do know most sources don't even run that......ultra bluray don't
Perhaps my post wasnt explicit enough. I was using the / to indicate and~or, so I was asking if the adaptor supported one of the more common 8bpc colour formats without any chroma subsampling, not 24bpc, which I dont even think is a thing.
Also random web browsing from the sofa on my HTPC NUC.![]()
