I don't think you're being unreasonable, but I think you're probably making this harder on yourself than you need to.
You obviously have no patience for this and she's clearly picked up on that.
If she's messing up because she's in over her head, then be kind and help her. You'd want the same to be done for you if the tables were turned. What's more, it's in your interest in the long run as you won't have to be picking up slack or otherwise underperforming.
Change your attitude, give the girl some guidance and be more approachable. Your line manager is likely to notice this and it will only bode well for you in the long term.
. I went to perm interviews hating the routine of it - the whole permanent mentality. As a contractor most of that is no longer relevant - it's more about "can you do what we're asking for, for the x number of months?".
