The co2 stuff any good? It seems like a good in case of emergency type fix, but not used them.
I normally carry a spare tube, levers and small pump
One negative is that you need to kinda let the CO2 out the tyre and re-inflate with air after you get home because the CO2 leaks though the innertube a lot faster then air so the tyre will be almost flat by the next day.
