Balky... the Svapiamo VTC Mini Squonker is a great mod, you get both a 16.5 and a 22.5 juice cup that you can easily change in 30 seconds, the juice bottle is only 6ml, but for a day in work thats enough juice for me running a Dual SS coil at 0.25ohms and 50w with TC limit set to 195C.
The VTC Board is good, with the V2.0 Firmware it came with, it worked in TC mode with the 317L SS coils straight away, but with the V3.0 that takes 20 secs to install, it now shows SS 316 but still works great and now has M1, M2 and M3 settings for three different Custom TCR values you can set and save, the screen layout changes slightly with the V3 FM, but i think for the better as the ohms and amps on the previous FM display were tiny, now the Ohms is bigger and easier to read and the amps can be changed to puff or time spent which is nice.
In all id buy this again, the fit and finish is good, no rattles and the door fits very snug with very strong magnets.. to be honest, my only nit pick would be getting the battery out, it could do with a ribbon, otherwise i love it, small, light and plenty of power with TC support for multiple wires and custom TCR... get one... you wont regret it.
