So you are saying that if you find that the sound card is buzzing and this is down to your Fury Card, then you will return the Fury card and the monitor?
Firstly this card and monitor are a great combination, as quite a few of us have them and are having no interference probs at all AFAIK. Well it's the first time I have heard of it on the OCUK forums at least (I obviously don't get out enough
Wouldnt it be a cheaper option to get a new sound card or even RMA the Fury first (If it is indeed the issue).
I may have gotten the wrong end of the stick here, but it just seems crazy to me.
I am still running an old Soundblaster Fatality card and never had no probs whatsoever with any other card causing interference. I hope you solve the issue quickly though, whatever you choose to do
Sorry for the late reply, been playing about with it a bit more.
You're right, it is a great combination and apart from the interference I'm very happy with the both. The reason for saying I'd have to return both is that if the Fury went I'd have to go back to my old 7970, which I just don't think would cut it at 1440p/144Hz so I'd be back on my old 1080p monitor.
Sound cards is a whole other issue! I had - and still do somewhere - a X-Fi Elite Pro, which I loved and ran for years but when I built the rig I have now it just didn't get on with it for some reason. I had the random switching of channels bug, which I first had on Vista on an old build but playing about with custom drivers etc it fixed itself. But what ever I did on the current build it just wasn't happy.
So I then ran on-board sound for a bit but was never happy with it.
Eventually got a Creative ZxR, which was a step up from the onboard but again wasn't overly happy with it as to my mind I still preferred my old X-Fi.
So I'm now on an ASUS STX II, which - IMO - is a good step up from the ZxR and I've been pretty happy with it since having it.
I think a big part of my problem with the interference is the number of cables etc in my setup. Normal stuff for the PC wired up on the desk but then it's also wired up out to the TV and 5.1 analogue out to a home cinema amp etc. The interference didn't seem to affect the mic input or the headphone output, so I can only put it down to the analogue cables out to the amp.
Anyway... the upshot now is that I've now got it to the point where the interference is basically fixed. I initially re-jigged the power cables from the PSU to the sound and GFX cards and moved the sound card to another slot - this is a bit of a pita as it now means it's sharing lanes with the GFX card, so the GFX card is now running x8 not x16 but no biggy.
That got it to the point where it was bearable at low to mid volume on the amp but still there if the amp was turned up but nowhere near as bad as before. But I've now added a 'ground loop isolator' to the one set of phono leads for the L/R front channels and that has pretty much got rid of the interference to the point that I can now live with it.
I may now look to move the sound card back to the x1 slot so I can get the GFX card running back at x16. I'm also tempted to dig out the old X-Fi and see if I can get that working again as I can stick that in the PCI slot right at the bottom and it won't be using PCIe. I'm also still on Win7 but do plan to move to Win10 at some point, so maybe that will fix the X-Fi issues I was having previously.
tl;dr = Moved the sound card to a different slot, re-cabled the PSU to sound and GFX cards, installed a 'ground loop isolator'.
