Man of Honour
- 13 Nov 2009
- Northampton
With regards to earlier posts re 26650 mods, as some of you know, i had an sx350j 26650 mod, and i have a few Shockle 26650 cells, they are 3500mAh, 30amp from Torchy, anything i saw over 3500mAh were lower amp or did not hold up as well based on reports and graphs.
Now 3500mAh may sound good and it could be down to the naff sx350j, but i found battery life to be no better than a good 18650, now as i said it could be down to the sx350j as it seams to stop regulating once you get below nominal voltage and just dumps whatever battery power you have left, you can feel it in the vape as it gets weaker, like using a ego battery... so im guessing fewer mods use the 26650 for this reason, they are not better than 18650... just because they are bigger and Plumes guys noted that they felt drop off and bad sag on the VF Stout with the 26650 cell... so im not hold too much hope in having great battery life from a single 266650 mod.
But the Stout looks good and was cheap, and i dont like having cells i cant use so thought what the heck lol
Norbert (Ecolux) does some Keepower cells that 4200mah 20A and 5200mah 15A iirc
Edit: Moochs test on the 4200mah cell
https://www.e-cigarette-forum.com/f...st-results-only-20a-but-high-capacity.710293/
