No, the drive connectors are SATA.
The P410 works just fine in the Gen8.
I use VMWare so no idea on driver support at the OS level.
Thanks, I'll try and pick one up cheap.
Is this all that is required, aside from SAS cables to connect the drives to the controller?
- FYI. The battery back cache took over a week to charge in my case. 0.oYup, I think I used the same seller- FYI. The battery back cache took over a week to charge in my case. 0.o
I unhooked the SAS cable from the port on the motherboard and hooked it into that for:
A - it gets around the SATA2/3 issue.
B - Raid 5
Then I picked up a break out cable and shoved 4 SSD's in the top with some power splitters.
You shouldn't even need cables.
I have the N40L and the connection that comes out of the drive cage is Mini SAS, which is the connector that's on the P410 and P420 RAID cards.
I've had a quick look at photos for the Gen 8, and it looks like it still uses Mini SAS, so you'll be fine.
(If you wanted to run more than just the 4 drives in the standard drive bays only then would you need additional cables)
The Gen8 uses a Mini-SAS port to 4xSATA.
Restrictions on the onboard controller means that ports 1-2 are SATA3 3-4 are sata2
In that case, do I even require the P410? Can I not just get a mini SAS to regular SAS if such a thing exists?
Sorry, trying to catch up with all the terminology. The P410 is the HBA, correct?
So to double check all I need is the P410 and I can hook up my three 4tb SAS drives to the gen 8 box?
If so shall I order this tonight?
http://pages.ebay.com/link/?nav=item.view&id=262233733880&alt=web
You'd need a low profile bracket. Not used a 410 personally but if others have then yes shouldn't be a problem.
I have Streacom ST-NANO150 in my N54LOwned my microserver n40l for a good 4 years and today it just packed in. Although it's been on 24/7 for just as long so I can't complain, hah.
I think it's the PSU related, will confirm this afternoon.
Has anyone replaced their one with a new PSU, if so which one?
A little more pricey, but is this a better option?
http://www.ebay.co.uk/itm/252265886118?ssPageName=STRK:MEBIDX:IT&fromMakeTrack=true
