Show Us Your Motors!
I actually quite like the Avenger. I know it's probably not a good car, but at least it stands out in a sea of Mondeos and Vectras.
Well to tell a secret, it's actually Diesel :o
They use a 2.0 unit sourced from VW for the EU market. Which is part of the appeal for me.
I started a new job a few years ago with a bit of a commute, and the 2.5 V6 in the Cougar was killing me fuel wise. I get high 40's MPG in this. So it suited me fine. I like American style but I need German fuel efficiency.
I wish! You should have seen this place, 6 or so space car garage (and spacious too) with cars under covers and what was close to a mansion next door. You could have eaten off the floor of the garage. The 458 Speciale under one of the covers was absolutely stunning - and they aren't even for sale, just as an investment. The bit you see is the room build onto the end of the house. I am definitely in the wrong profession.
Does look like a special place.
Something for us mortals to aspire to? :D
bought this for the wife to replace her citroen
£1200 57 plate bargain
had it valeted today the smoke is from the fog-it machine.
I have AP two piece discs and mine went the same after a few sessions. Horrible feeling through the steering wheel! Slightly annoying when paying £700 just for the disc rotor!
Disappointing indeed. I do wonder if it could be down to the calipers, they are a fairly low end OEM Brembo unit.
Clarkey - Can you swap with Pagid RS29's? I know the RC6 are a better pads but they also run hotter too potentially causing more disc issues.
In fact what about the RC6 Endurance pads, these should also run cooler than the RC6.
