You know eurocarparts lets you put in your reg then it'll show you the right parts? You don't have to keep asking other people to find it for you! If it lists more than one grade then check your manual for the right stuff
I wouldn't want to guess, but if I was doing an oil change then for the five quid the filter costs id just change it anyway
What else do they do on oil service?
Do they do the air filter aswell ?
Plus your talking rubbish. For effect.
you're telling me all this work can be done for 500?
great I have national breakdown cover tell me the garage and I'll get it towed there
I'm waiting....
Update:
Got the Handbrake done
Wheel bearing
Oil/Filter change
new crank pulley
replaced all the belts
She now drives like I a dream. She purrs like a kitten...
TBH when the mechanic showed me the state of the crank pulley and the movement it had and the state of the belts I understood why my car sounded like a rattly sack of ****
Qty Part# Description Vehicle Price
1 202110590 Dayco Drive Belt BMW 3 Series 2.0 2003 £28.00
1 521776081 TRIPLE QX 5w40 Fully Synthetic (For PD engines) Engine Oil 5Ltr £24.99
1 521776082 TRIPLE QX 5w40 Fully Synthetic (For PD engines) Engine Oil 1Ltr £6.77
1 501110267 Bosch Oil Filter BMW 3 Series 2.0 2003 £9.38
1 347110200 Dayco Crank Pulley BMW 3 Series 2.0 2003 £146.58
Subtotal £215.72
Coupon Benefit -£10.79
Total £204.93
Other parts for the handbrake and the wheel bearing cme to £68
[TW]Fox;29133634 said:
Not really as your mechanic would have sourced better prices from AP, GSF, Bullseye etc.
For instance, you paid the crackers price of £25 for your alternator belt when a Meyle one is :
http://www.ebay.co.uk/itm/MEYLE-V-R...018315?hash=item540b7d5e0b:g:lAIAAOSw-nZTqAUK
£7..
Or the crank pulley can be had from Gates
http://www.ebay.co.uk/itm/BMW-3-Ser...459666?hash=item3cfca12f92:g:TMgAAOSwHnFVhC5O
Crackheads use ECP nowadays.
Just gonna throw this out there, maybe public transport is a better option for you?
I can't see it being any fun running a car on such a shoestring budget? Or maybe downgrade to something like a Fiesta or a Toyota of some sort?
Apologies about the mechanic comment, yours may just be crap at it. I didn't enter the party earlier as I just didn't fancy explaining to someone how to attach a fan belt.
You need to chill out. Also around which post number are you discussing the pricing of the belt and crank pulley?
Bottom pulley is badly worn which could cause the belt to come off and you will then lose power steering on your vehicle. £280
You have every right to be angry at me, I'd be angry to if I paid extra.
I'd also change..
Air filter
Plugs
Fuel filter
^These with the oil & filter is a decent service for your engine.
Pollen/cabin filter too. (This clears out dead leaves/bugs that would otherwise be rotting in your old cabin filter, so the air in the car is 'nicer' for the occupants)
Following that..
Brake fluid
Clutch fluid
Gearbox oil
Coolant
Fresh fluids/filters on a car at the recommended intervals will make it last a lot longer and be cheaper in the long run. Helps prevent mechanical failure and keeps your fuel usage in check.
The super basic and easy to do yourself from easiest to hardest are..
Air filter
Cabin/pollen filter
Oil
Oil filter
Then harder..
Plugs
Gearbox oil
Coolant
Clutch fluid
Brake fluid
(Can vary between cars)
Plenty of Youtube guides for every car!
