How do you test it string?
Ok will have ago now. Just tried a little bit but mine was hitting 3506.
You hardly got any awards, rushing each level i see![]()
Of course it will hurt sales but that isn't the main reason for games having considerably more sales on consoles than pc..... There are so many other factors that come into play that I would consider piracy to be a very minor one in comparison.
Hi everyone,
What a great game this is.
How can I check what fps it is running at? Is there an in game command?
I can force crossfire on using Optimize 1x1 or AFR friendly..and generally get good FPS but weird flickering from light sources and text...Should I have a selectable pre-defined profile for ROTTR?
3505 here too constantly during gameplay
On custom profiles, the flickering is usually MSAA, turn it off and the flicker should stop, try VSR instead.![]()
Also the amount of people on here that have bought the game for £6.00 off windows store pretending they live in Ukraine. That is not really much better than piracy.
I have never heard of that happening on a console.
Thing is, why was/is it £6 in Ukraine anyway? Are games generally a lot cheaper there for some reason?
