- 17 Nov 2005
- Chippenham, UK
Your line must be heavily impacted if you are only achieving 22805 down and 7852 up.
Have you removed the ring wire from the master socket already? If not I would suggest doing so, really easy to do takes 2 minutes. See here, scroll down a bit
Router stats; if you could post up your current/max sync if shown along with the SNR, attenuation etc that would be useful.
Something has gone right. It's now 23623 down.
There is only two wires connected in the master socket, the ring wire was already disconnected.
I use an Openreach modem connected to a Tomato based Cisco Wireless Router, so I can't see any router stats. (or can I?)
