- 30 May 2009
- Maidenhead
Liege Bastogne Liege?!
As you're still losing weight, is it having much impact on your waist? If so I would hold off spending ~£100 on Assos shorts which are not going to fit you once the warmer weather arrives...! ASV windslam is great too! I even messaged them to ask if I could have it at the same price as last week (£42) and they gave me a £6 refund!YMMW.
Yup, Liege Bastogne Liege. We're not doing the full-fat version though! The middle distance (so not actually going to Bastogne).
As for my waist: I'm still aiming to lose between 7 to 10kg. However, as much as my wasit has reduced, my dhb Aeron bibs I bought when I first started still fit me just fine (and I dropped from 84kg to 67kg). I'll probably only lose another 2 inches max on my waist (I'm currently around 31 inches), and I have pretty wide hips for a short man (5 foot 4 as I mentioned before). So the smalls should still fit me fine.
Ace, I'm going to pick up one of those tops then. Do you just wear a baselayer with it? Or a gilet on top?
YMMW.
