Cant wait to see the your new Focus ST next month.
After spending money painting the BMW
It's got stop start which I am not keen on, so need to remember to keep my foot on the clutch at lights and stuff which is a bit annoying![]()
[TW]Fox;29198942 said:Trust me on this - stick with it for a month. You'll get used to it and once you do, it's absolutely fantastic. Sitting at the lights in silence is brilliant.
If you still hate it after a month you'll always hate and can thus just turn it off, but give it a chance!
Because turning a key is so difficult.![]()
Great for sitting at traffic lights for a few mins but crawling in traffic waiting to join a roundabout and its awful imo.
[TW]Fox;29199156 said:What? stop start is nothing to do with turning a key![]()
I was making the argument that stop start is pointless because you're either going to be stopped for such a brief moment that it is annoying, or if you are stopped for a long time, you can just turn the car off and on again with the key...![]()
[TW]Fox;29199188 said:It's not pointless at all. You are not going to manually switch the engine on and off all the time when sitting at lights etc. Especially as doing so usually switches the aux functions off etc etc. Start stop can also automatically restart depending on system load, if it it detects that running the AC compressor is required for comfort reasons, or if the electrical load on the car reaches a certain point.
I can only assume you've never driven a car properly with start/stop or you'd not have suggested that.
No one keys off really though. Stop start has the necessary hardware upgrades and will restart the engine if voltage starts dropping or brake vac pressure drops.
Basically you've never driven a car with it have you?
