alright will get em running tomorrow morningoverclocked i7 these days. Have used the C2D app. Good for ivy?
MORE SPEED CAP'N! MORE SPEED!
I have two X99 boards but no CPUs for them
might be able to dig up a laptop or two but not enough to make a noticeable difference...gcc-multilib is a bit of a sledgehammer fix (I found that one while looking for the one I used), but if it works, then don't knock it.Not sure if this will help anyone but got it working under Ubuntu server 14.04 64bit with this...
Beware that glibc has a DNS-related vulnerability (well publicised, so look it up if you want the gory details). Anyone installing now (at least with 14.04) should get a patched version, but if you've got older Linuxes floating around, be careful.
now 3rd![]()
I kind of see you, me, and PDW moving up as a bit of a block to be honest.
Ah, struggling to keep up with you now Chris.
2.5 days left to try and overtake ozaudio and keep Streetlight at bay.
