Back wheel off today, was planning on taking the rear brake caliper off and cleaning it up, copaslip on the pin threads, clean the pins, etc.
But, with a single sided swing arm the bolt I need to get to to undo the caliper bolt is between the chain and the disc, so I can't get to it.
I'll leave that one for Triumph then.
Got about 1mm of the groove left and service is in May, so might just ask them to replace pads for me while they're at it.
