cant wait to get home now and try this monitor out
Indeed, appreciate the effort put in to writing that up
The SW Battlefront screenshot is perfect for demonstrating the interlace-pattern artifacts issue I was seeing. If you don't mind me saying, I personally feel you're downplaying it, but I understand that some people may not be bothered.
I wonder every panel is affected to the same degree, or if some are worse than others.
WOW what a detailed reviewcant wait to get home now and try this monitor out
How long did that take you to right?
ordered mine today, was tempted to push the boat out for the acer IPS or ASUS but with so many people running into issues I went for this.
Coming from a Benq XL2411T so lets hope I see an improvement![]()
Something not right so can't get monitor above 120hz and also in BF4 there's bad screen tearing??
I will re-install the graphics drivers and see what happens.
back in a mo.....
NCP
Monitor tech = G-Sync
single display max performance
prefer max performance
preferred refreash rate = highest available
V-sync = off
Yeh, little strange but it works. The 770 only supports 120hz as well I believe, so you probably won't get higher. But it's really going to be very little difference from 144hz.
Oh really?? thought i read G-sync overrides V-sync
I will try this thank you
My 770's went upto 144hz on the 1080p screen? are you saying because the new screen is 1440p??
Don't forget the biscuits.![]()
But it certainly doesn’t cut back on those more appealing gaming features, with a potentially very responsive TN panel, 144Hz refresh rate and support for a trio of Nvidia technologies; G-SYNC, ULMB (Ultra Low Motion Blur) and 3D Vision.
I came from the same monitor and I'm more than happy with this, Gsync is great![]()
