I have some wheel sealant, but it says to use it weekly. I think I'd probably rather do it fully, take them off, clean and then seal with the type you leave for 24 hours, then they don't need doing for a year.Any decent wheel cleaner solutions? I'm using car chem revolt at the moment which is ok but it doesn't go far and it absolutely sinks...
Thanks for the heads up RE waxing the wheels, never thought that was a thing but I guess it's just paint. I have a tub of collinite wax, is that ok to use or does it have to be temperature resistant wax as mentioned above?
What products, pads and polish etc did you use with your DA?
It should be OK but I wouldn't quite expect the lifespan you'd get on bodywork. For a wheel sealant ideally you want Gtechniq C5 but try the wax first
Pad
Pad Lube
Polish
1st Wax Coat
2nd Wax Coat
Just to add, I used this clay and it's the best I've used, it's insanely sticky yet soft and very easy to work with unlike some harder ones I've had before.
