** The Official Space Flight Thread - The Space Station and Beyond **
I believe that for Apollo 11 the LM Environmental Control Subsystem (ECS) supported two for 24 hours on surface and another 24 hours flight time.
Their space suits also had a Primary Life Support System (PLLS) with around 4 hours support and 1 hour reserve time.
Interesting question.
The first landing missions (11 through to 14) weren't set up for especially long duration missions on the lunar surface. I know 13 was carrying oxygen to support two men for 45 hours - 13's mission (before it all turned to worms) was going to involve two excursions onto the surface so would require more oxygen than 11, with having to depressurise and repressurise the cabin twice. That might still have been achievable with the previous missions though.
If you assume that 11's LM was carrying the same amount of oxygen as 13, then you've got a 45 hour supply. But there's also battery life and water - not only for drinking, but for cooling the spacecraft systems - to consider. You can have all the oxygen in the world, but if the spacecraft systems no longer function because the batteries are dead or the systems have overheated then you aren't going to be alive for very much longer! Also there's the carbon dioxide to get rid of - Apollo used lithium hydroxide canisters to remove it from the atmosphere inside the spacecraft, but they become saturated after a while and no longer usable. 13 ended up stretching their LM supplies to keep three men alive for about 90 hours, using minimal power draw (which also kept water usage down since there were fewer systems to cool) and adapting command module lithium hydroxide canisters for use on the LM. I'd figure on 11's supplies probably not making it quite that far, even with only two men inside.
Yeah no idea for 11 but for latter landings it was 75hrs.
Awesome thanks guys !! so were looking at 24 hours LS in the landing section of the lander Cosimo ? Then another 24 in the ascent stage? Or was it all in the ascent stage?
The life support is in the ascent stage. The descent stage supports landing and surface activities.
If you want to dig around then:
LM Environmental Control Subsystem:
https://www.hq.nasa.gov/alsj/alsj-LM-ECS.html
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19720013195.pdf
LM systems diagrams:
http://www.ehartwell.com/LM/SCATSystems.htm
Expedition 47-48 Soyuz Commander Alexey Ovchinin and Oleg Skripochka of Roscosmos and Flight Engineer Jeff Williams of NASA and their backups, Sergey Ryzhikov and Andrey Borisenko of Roscosmos and Shane Kimbrough of NASA preparing for the 19th:
Hopefully the first of many 360° views of the space station. Here we have first module, Zarya. Launched on November 20th 1998:
Also known as the Functional Cargo Block, the module is now mainly used for storage.
We have another 360° view. Here we have the second module, Unity. Launched on 4 December 1998 inside Space Shuttle Endeavour, it was joined to the Russian Zarya module two days later, forming the basis of the International Space Station:
Also known as Node-1, the cylindrical module has six docking ports to connect visiting spacecraft and other modules.
Expedition 47-48 Soyuz Commander Alexey Ovchinin and Flight Engineers Oleg Skripochka of Roscosmos and Jeff Williams on their way:
