Vega isn't Polaris exactly, from what they've said. It's an argchitectural upgrade. They're claiming significantly higher performance per watt than Polaris, and HBM2 won't bring much in the way of performance per watt, if anything.
Something others seem to have missed is that AMD have stated that Polaris 10 & 11 are not the only chips - others will follow.
They also stated that Polaris has been made compatible with GDDR5 and HBM.
If the images of Polaris 10 & 11 chips in the slide were scaled somewhat correctly, then Polaris 10 must be around 350mm2 or slightly under. That's fairly big, and no surprise that it apparently matches or beats Fury X / 980Ti. Koduri hinted that the big Polaris would be shown later (with HBM).
Given the significant reduction in chip sizes with 14nmFF, it shouldn't be difficult for them to have 6 stacks (or maybe even 8 stacks) of HBM1, and therefore have a 6GB or 8GB Polaris HBM1 card. Tbh I don't even think it's needed in terms of capacity ... but I suspect the extra bandwidth is absolutely necessary.
One other thing ... the 2018 architecture. It'll be very interesting to see what that memory turns out to be. I assume it'll be either Wide IO or their own proprietary standard. If they need more bandwidth that early, then HBM isn't gonna work ... too much power consumption. Also very interesting that NVIDIA seem to have abandoned HMC entirely (no surprise), and will be keeping HBM2 for Volta, probably until 2020. That would be a major divergence.
HBM has way better perf/w than GDDR5(x). So this alone would make a big difference.Interestingly Vega is meant to have better performance per watt than Polaris? Since it is the larger chip it needs to replace Hawaii for professional markets so has stuff dedicated towards DP performance.
A 4-8gb GDDR5 vram card could pull about 30W more than a HBM equiped.
It's not about the capacity, it's about the bandwidth. Memory bandwidth becomes a bottleneck as soon as the core clock on Fiji is raised above 1000Mhz. Imagine what big(ger than Polaris 10 / 11) Polaris is going to be like if it has GDDR5(X)? It needs HBM, and more than 4 stacks .. preferably also at higher than 500Mhz clocks. There's apparently a completely new L2 cache design** for Polaris, but I doubt it will work miracles re: bandwidth requirements, or they wouldn't be champing at the bit to get to HBM2, only to want to abandon it for something newer a year later
** I suspect its main purpose is to reduce latency further - very useful for VR.
ninja edit i think, im sure he said twice as fast originally lol
The FXs real problem is HBM1 clockspeed.
I would have thought the opposite. Being stuck on 28nm for so long, their only hope of providing continuing gains was to push ahead architectural improvements in order to satisfy consumer demand for more performance.Agreed. I think that both AMD and Nvidia have been saving up big architectural changes because they've been waiting on the process shrink/transposer/HBM to take full advantage.
They've had longer to get ready for this process shrink than any other shrink in history, and I think they want to make the most of it after being stuck in 28nm limbo for years.
If Vega 10 and Vega 11 are the higher end GPUs with DP compute added,they should be less efficient than Polaris 10 and 11 which are probably compute light,so if that is the case,AMD HBM2 can't be the only saving grace IMHO.
Remember,AMD Fiji was much slower than AMD Hawaii in DP compute. I suspect Vega will replace Hawaii as the basis for the AMD professional cards,unless OFC AMD has another larger Polaris GPU in the works.
I think the problem is the immature technology. Matt said that clocks are locked at certain intervals. Even if you supposedly clock it to 600Mhz it really runs at 570mhz or so. This tells us that memory controller is still young. Who knows maybe Polaris will come with better mem controller and HBM1 will be refined enough to have more flexibility.
FX suffered more from driver overhead than anything related to HBM.
It isn't uncommon for memory to run on set dividers going up in steps instead of individual units - it isn't necessarily an indication of any immaturity in the implementation.
Some minor issues aside HBM doesn't really do anything particularly positive or negative on the Fury cards (aside from limitations on the amount in situations where you really need it) its not so much that the memory tech is young but more that with current architectures in terms of performance it largely doesn't really offer anything tangible that GDDR5 doesn't do just as well.
What really harms Fiji is being on 28nm rather than sub 20nm planar - they just can't fit enough of certain things that are important to performance to pull away from nVidia's ability to brute force it on Maxwell.
AMD going to smacked again, seen as they are using GDDR5, while Nvidias using GDDR5X ?
The gcn architecture works by fusing two 32bit units to perform a 64bit calculation. GCN has always been capable of 1/2 DP on all parts as there is no dedicated DP units in the architecture.
Fiji is also capable of 1/2 DP the same as Hawaii. So vega will gain improvements from architecture/ process tweaks and HBM2.
Only driver locks limit the DP capability of the parts.
GDDR5X isn't even scheduled to enter mass production until "summer" according to Micron. I find it very hard to believe that either side's cards will be using it if they're due on shelves in late May/early June.AMD going to smacked again, seen as they are using GDDR5, while Nvidias using GDDR5X ?
If Nvidia is using GDDR5X so would AMD. I expect they will be using GDDR5 still.
I didn't know that - it seems quite flexible.
So since Nvidia is touting mixed precision from Pascal,isn't that what AMD is kind of already doing??
I wonder if Pascal,Polaris and Vega might be well matched in the end??
AMD trying to reduce power consumption of GCN and improve DX11 performance.
Nvidia adding back more compute and improving DX12 performance but already having demoed most of the power saving tips.
