- 31 Oct 2005
- Wirral
google play store, amazon app store, and the samsung app store all working hereApp store has gone down for me, anyone else?
So was trying to show off my camera on this thing and it back fired, see below...purple flame.
http://imgur.com/wFsHdY3
Did people use the Samsung data transfer thing when they got their phone to copy over stuff from old phone? What exactly does it transfer?
All I need is contacts which are saved to Google anyway. Apps can redownload and media is on sd card.
Am I better just syncing Google as usual?
Righty. just got a S7 edge, linky me some good cases, also whats the jazz with 'screen' protectors these days? never had one with my S5.
Thankeee!
Don't forget anyone that needs to redeem their gift the 14 days are up.
just got these today. yet to put it on as i have a Zagg screen protector attached which looks good.
i only ordered one but 2 have arrived
on first impressions it built very well.
Downside is i've had to use both due to the glass not fitting with my Spigen Neo Hybrid case and popping the glass off. The adhesive after two or three applications became nona adhesive and won't stick anymore.
Even the second item i've only applied once hasn't stuck as i thought it might. Have had to go use my Spigen thin fit as that doesn't cover the glass edge.
I paid £16 for this item and was expecting better tbh.
Hopefully Nuglass will produce one which fits better
The adhesive is only on the black parts of the glass and not like other tempered glass where it's covered all over.
Thankeee!
Got the below for the standard S7 today, looks good overall. I have linked the edge version which is cheaper for some reason (I bought from same seller as linked):
http://www.amazon.co.uk/gp/product/..._rd_t=36701&pf_rd_p=867551787&pf_rd_i=desktop
Consumer Reports names Galaxy S7 and S7 edge "best phones ever"
What gift?
Can you not squeeze another one in?
