***** The Official Division Thread *****
Ooo there is a nice Navymp5 n on the DZ vendor for tech guys. It's commanding talented and fierce
Gah I do like the crafting system but some of it is just pita... They need to allow you to craft high end divsion tech with the lower grade division tech
Which extended mag is worth getting for the vector? I was saving for the PC one but not sure if it's worth it over a purple.
The PC extended mag should be the first thing you buy. I rolled for ROF 28% and 92%mag size
Keep crafting until you get a rate of fire and mag size one. That's the one to go for on the vector.
You want DPS ? nothing beets firing more bullets and for longer without reloading. Vector has so little recoil you don't need stability mods.
What sort of health do I need to not get one shotted by the Russian consulate snipers on challenge mode. Completed other challenge missions fine
I find PC easy. It's the High end divsion tech that pita.
I just did the tunnel over and over again until I got good gear and 30pc each go.
My vector must be broken then, its so unstable compared to my aug that i end up never using it.
These daily missions are pretty much impossible solo, horrible.
Grinding up to 150 phoenix credits is going to be nigh on impossible.
You just need a few more purples but eventually Hard Mode is a walk in the park, I just run around melting them. Challenge is obviously harder, but 1 or 2 are more doable with just 2 of you
I've just turned L30 and found the Hard modes a walk in the park as a group, we ended up sprinting through it. Challenge was harder, managed to break our way through the initial parts but came unstuck when we couldn't get out of the starting position.
I would prefer the hard modes harder though. Challenging was fun though.
Still only on purples and a couple of blues.
Seems like everyone has the vector, be better if there was reason to use the other guns.
If they sorted out the High End Division Tech bottle neck they would, i'd happily be using an MP5 or an Aug but can't afford the crafting mats to keep rolling :(
I preferr the cadecaus (or whatever its called lol) over the yellow vector - whilst it suffers from high recoil after the first three shots it's got some serious stopping power!
Finally got all yellow gear - I could swear I got better drops from doing the daily on challenge mode than just re-running the lincoln tunnel on challenge mode for example.
