Is it just me or do Echo cause the game to crash fairly often? I've had three, maybe four crashes now and every time has been during or exiting an Echo playback.
Nope, not had any issues at all.
I'm talking about the High end gold level 30 one that the Advanced Vendor who is located upstairs in the Tech Wing of the Base of Operations sells the blueprint for.
http://www.accelerated-ideas.com/thedivision/which-highend-weapon-to-get-first.aspx
Which extended mag is worth getting for the vector? I was saving for the PC one but not sure if it's worth it over a purple.
Cool ta. Those stats are fixed right?
These daily missions are pretty much impossible solo, horrible.
Grinding up to 150 phoenix credits is going to be nigh on impossible.
The PC extended mag should be the first thing you buy. I rolled for ROF 28% and 92%mag size
Keep crafting until you get a rate of fire and mag size one. That's the one to go for on the vector.
You want DPS ? nothing beets firing more bullets and for longer without reloading. Vector has so little recoil you don't need stability mods.
You just need a few more purples but eventually Hard Mode is a walk in the park, I just run around melting them. Challenge is obviously harder, but 1 or 2 are more doable with just 2 of you
I've just turned L30 and found the Hard modes a walk in the park as a group, we ended up sprinting through it. Challenge was harder, managed to break our way through the initial parts but came unstuck when we couldn't get out of the starting position.
I would prefer the hard modes harder though. Challenging was fun though.
Still only on purples and a couple of blues.
Seems like everyone has the vector, be better if there was reason to use the other guns.
